- Apr 11, 2015
Thanks for your likes and comments, guys! I should add - if any of you see me making a mistake, please let me know. In that other site, nobody told me that I was making a mistake painting the windows gold instead of white, and now I wish I had painted the window frames white because all that gold is a little too much. Too late to reverse that decision now. I have also made a number of deviations from the plans and from what I know to be historically correct. The crows nest is one example:
I know that the whole thing is supposed to be painted black, but I elected to keep the pearwood natural because I thought it looked better. There may be other mistakes that I made inadvertently, and feel free to tell me before it's too late.
BTW, I did not show the fid earlier. This was made by cutting off the bottom of the topmast / topgallant mast, and a square hole cut using the Byrnes table saw as a dado cutter. The removed part was then glued back on. When the glue was dry, a hole was drilled from the bottom, through the fid, and into the rest of the mast, and the whole thing was pinned. It was then sanded flat and painted over. You can not see the cut even if you looked.
Likewise, the masts should be left natural or painted black. I painted them white because white lower masts are a little signature in all my ship models.
Some homework I need to do: work out how to lash the boats so they won't come off.
