When doing a fibreglass course a few years back we were warned against using acetone to remove epoxy from skin, it actually drives the epoxy into your pores, I imagine acetone would do the same with ca.but who wants solvents leaching into their skin?
For sure It's not healthy for normal use. The CA debonder is probably acetone-based, it works only slightly faster than regular acetone.When doing a fibreglass course a few years back we were warned against using acetone to remove epoxy from skin, it actually drives the epoxy into your pores, I imagine acetone would do the same with ca.
I use acetone as a ca debonder but definitely not on my skin.
I don't have any to 'snif', is ca debonder acetone based ?
Acetone is an exceedingly dry chemical related to alcohol. They bubble ether through it to dry it. It goes right through the skin and blood vessel walls. It bonds to water which we are mostly composed of. It may also go through the blood/brain barrier. Why are so many fiberglass workers alcoholics — I always wondered….For sure It's not healthy for normal use. The CA debonder is probably acetone-based, it works only slightly faster than regular acetone.
