I have a non-stick mat that was sold as a barbecue mat for outdoor grills. Superglue absolutely does not stick. A cut off a small piece that I use to keep my fingers away from the joint being glued when finger pressure is necessary to keep parts together until the glue sets.I think over the years I've glued my project to the mat more than to themselves.
I read that Super glue won't stick to silicone.
I'm thinking of buying a silicone mat to glue small pieces on. My self-healing mats are scarred and bumpy from super glue incidents, I try to be sparing and careful, butttttt.
An suggestions?
Was it not developed in the late 1960's in the US as IS12? Where the initials I.S. stood for Instant Suture. I heard it was availabe for field emergency medical kits in the Vietnam War? Thats why it sticks so well to human skin.CA was designed to bond best between two parts that have a clean tight fitment and are held tightly together while the CA cures. For example, hold two parts tightly together and use CA thin to wick between the parts…classic CA. The point being CA often adheres parts when they are tightly held together then otherwise. If there are gaps then use CA thick or gel. Just an interesting observation on the question of what CA bonds.
Yes indeed! Still used for same…as our fingers attest!Was it not developed in the late 1960's in the US as IS12? Where the initials I.S. stood for Instant Suture. I heard it was availabe for field emergency medical kits in the Vietnam War? Thats why it sticks so well to human skin.
Polyethylene. I use Polyethylene gloves works great and, on my table, tops. Usually been able to peel it off and remove parts accidently glued down. Usually used on green houses. bought from farm supply. Will stick to silicone.I think over the years I've glued my project to the mat more than to themselves.
An suggestions?
Walmart has silicone cutting mats ( Or a store like that) Not sure if there is a Walmart Canada?I keep seeing the advice to use a silicone mat which I’ve never seen in the numerous hobby shops that I frequent. Where would I find such for sale? Website?
phill
That let's out about 2/3rds of Hollywood "stars."I avoid anything that contains silicon. Silicone is a real plague that can destroy many things. I work in a large factory with advanced manufacturing. All use of silicone is prohibited. If silicone enters the manufacturing process, it is almost impossible to get rid of it. Silicone spreads like a virus and prevents surface treatment, gluing, sealing from being good. In shipbuilding it might not matter but I would avoid anything containing silocon.
