- Jul 20, 2022
Can you add more details please, Huc.
Colud you say what type of profile is it or what to type when looking in shop?
It’s the profile from the FET mitre. I re-used itColud you say what type of profile is it or what to type when looking in shop?
Because it's not regular T-track
I removed the vernier mechanism, found a deeper M6 nut, added a brass shim 0.02 mm, refitted & voilà! Virtually no backlash.
Next I removed the fence & mounting block, then I used 3 strips of 0.05 x 6 mm brass (I have no 1.5 mm) to shim out the slackness (up & down movement) & twisting of the block when tightening the lock lever.
Hey, Stuart. Any pictures would help. I wonder if you managed to make the vernier mechanism usable.Hi Yuri, will do my best, but not very visible.
Stuart
Hey Yuri, photos added, I bent the ends of the brass strips & added a spot of CA to retain them. The 3rd photo just about shows the nut with the 0.002" shim. The original 'vernier' does work good enough for me.Hey, Stuart. Any pictures would help. I wonder if you managed to make the vernier mechanism usable.
