just a question and hope to get some feedback. when building 2 or 3 masted ships i always run into the problem( when following plans and the measurements they give) of the top yard lifts fouling the top shrouds. I have seen some modelers run them through the shrouds,( as i noticed in latest "which victory kit is better-caldercraft or panart ) bent around the shrouds or tying another block to the shrouds. the only solution i can come up with is move the deadeyes farther aft on the top against the plan measurements or extending the cap to mount the blocks as far fore as possible, or delete the foremost deadeye. please let me know if you have experienced this problem and how you solved it. thanks in advance for you help.
