Not sure if I'm posting this in the right spot so please advise if not. I'm confused about the framing for the Blandford at the stern. When I look at the plans for hull construction pieces W4, W5, and W6 are aft of frame 63. But in the "Modeling instructions" it seems to show that W6 is actually attached to 63. If the hull construction sheet is accurate what pieces go where I've highlighted in purple? Are there other pieces that I'm missing? Also what is C1 and C2 for? Is it only for shaping the 3 W7 pieces?
Any and all comments, suggestions, instructions are welcome.
Thank you!
Thank you!
