The first picture shows how the frame was traced onto velum and then transfered to the wood.I just cut the form around the outside edge of the tracing and copied that line to the wood. #2 Then I took a small piece of wood the same size as I wanted the frame and made marks with it as a guide. Then the lines can be connected with a french curve to copy the outside line. Once the lines are drawn then it's off to the band saw. #3 That will produce a rough shaped frame ready for the oscillating drum sander #4 to further develop the shape. It's easy to sand the large frames but the smaller ones will need a smaller drum. #5 Is a picture of the hull construction of the Great Republic. It's of the actual GR and is accurate enough for me. That ship must have been like a cathedral inside.
By the way, has anybody ever built a boat that you could sail or drive? That might be my next step. Don't get excited, I'm just thinking ahead, that's all.
This is the cross section of the GR at mid-ship.You can see the heavy construction in her with the 10 sister keels (not 8) and the keelsons on the left and right to support the load along the hull. Then there are the ceiling planks along the hull inside, up to the Middle deck beam and some of that is doubled. Finally you have the outside hull planking and the keel sandwiching the whole thing together. It's amazing how they built these ships. There are thousands of iron and copper rods, some as big as 1 1/2" in diameter holding every piece of wood together through out the ship. No electric drills either. This ship is really built by hand.
