|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
I have managed to recover 6 out of the 7 small parts which have fallen through the deck hatch into the hull. That's a better than average score. Yes, it's frustrating enough to keep count. However, the brown carpet claims 15% of all the blocks and belaying pins dropped onto it. Carpet wins.I'm convinced small parts fall into another dimension!
What if you don’t fight this and build an old model from the beginning, as V. Zhdan doesMy models always seem to achieve that beaten, weathered appearance through lack of skill and experience in wood finishing and simple sloppy painting and workmanship!
Control of the amount of glue used per application and excess glue cleanup while working is something beginners often lack, and being able to paint with a steady hand along edges. I still wrestle with that.
 ? But you also need to be able to do this and try to do everything correctly. But this is already a separate art.
? But you also need to be able to do this and try to do everything correctly. But this is already a separate art.Yes, there is a parallel universe - in fact a specific planet- where all the lost springs, widgets, thingees and other small stuff goes.I'm convinced small parts fall into another dimension!
Because starting with the weather approach, and adding all the scrapes, scratches, wandering paint lines, and less than decent finish would make it far worse?What if you don’t fight this and build an old model from the beginning, as V. Zhdan does? But you also need to be able to do this and try to do everything correctly. But this is already a separate art.
 Absolutely! I drop parts and I hear them hit and bounce but I never find them! So somewhere there is enough parts to build another ship model…but darn if I can find them!Yes, there is a parallel universe - in fact a specific planet- where all the lost springs, widgets, thingees and other small stuff goes.
One big lesson I learned is to keep a bottle of CA de-bonder handy when using CA, for fingers sake....I thought frustration and this hobby go hand in hand. BUT, then something goes right, looks good and satisfaction comes into play. So you carry on building.
Like a golfer always trying for that hole in one.... maybe next time....
Biggest thing I've learned, know where, when and how much CA to use.
If only brass was magnetic.....Oh wait on.Yes, there is a parallel universe - in fact a specific planet- where all the lost springs, widgets, thingees and other small stuff goes.
One last mistake by beginners…not paying attention and keeping to scale. I think keeping model kit pieces parts in scale is difficult for most every modeler but those new to the hobby have a difficult time understanding the scale of the model. Easy example is the ring bolts we stick on the decks…we use what we can get for premade ring bolts but they are most often too large to scale. But other examples are spars that are too thick and deck treenails that are way too large to scale. Those new to the hobby learn the impact of parts out of scale…it is always better to go small rather than large. Trust your eye…we can often discern by eye when something doesn’t look right!
Or when one needs to use parts that are available but are really out of scale…eye bolts being typical. We use what we have, what the market offers us, and compromise scale…I do get this from a purist point of view. I always try to "think in scale" whenever working on a model, and I'm never without a calculator around the bench for ciphering sizes, especially doing scratch work. But... there's always the compromise that sometimes things do need to be a little out of scale for visual appeal.
I think this is the best advice… Works well as career advice too...Done this many, many times, but I can’t tell you how many of those times have been a double-edge sword. Get flustered by something, walk away for a week or two, then when you get in the mind to get back to the bench, it was a 15 minute fix… now pissed at myself for letting it get to me and miss out on two weeks of build time.
OUCH!My biggest mistake is/was not being patient. Take your time.
On the bright side, I also learned that most wooden accidents can be corrected.
