I'm building the Model Shipways Mayflower. I'm working on the shrouds. The directions say to loop the shroud around the mast so on the same side of the ship, from the deadeye, the shroud goes up around the mast then back down the same side to another deadeye. The problem is , say with 10 shrouds, 5 are leading down one side of the mast and 5 are leading down the other side of the mast. This creates an empty "V" at top end of the shrouds. The ratlines would not look right. How do I correct that or avoid it? John
