Is there a specified gaff angle? Most pics I see have them at about 45 degrees but every so often I see one steeper than that. can't seem to find anything in my books.
I agree with the first sentence unless there are reliable references indicating otherwise. Plans in kits aren't always based on the best research. I've seen examples of mizzen topsail braces running aft to the peak of a lateen yard but I don't recall that arrangement on a gaff spanker. The mizzen braces typically run forward. Do you have any examples of the braces running to a gaff?If you're building a model of a ship that existed, it's probably best to go what's shown on the sail-plan rather than make something up.
Square rigged vessels, into the late 1700s often peaked their gaffs lower because the mizzen braces ran to the peak of the gaff. If the gaff's peaked too high, you don't get the required leverage on the braces.
Andy,I agree with the first sentence unless there are reliable references indicating otherwise. Plans in kits aren't always based on the best research. I've seen examples of mizzen topsail braces running aft to the peak of a lateen yard but I don't recall that arrangement on a gaff spanker. The mizzen braces typically run forward. Do you have any examples of the braces running to a gaff?
Fair winds!
James Lees says; "...up to 1805, [braces] led aft with the standing part made fast to the peak of the mizzen yard (lateen) or gaff, the running part rove through the brace pendant blocks, back through single blocks on a span round the mizzen yard or gaff, just below the standing part, and the brace led down to the rails by the transom....from 1805to 1815 the standing part of the brace was seized to the main mast head..." (Masting & Rigging page 94)The mizzen braces typically run forward. Do you have any examples of the braces running to a gaff?
Even different builders in the same nation at the same time period would sometimes do things differently, so when you add different nations and different time periods, a single book to cover it all would be a gargantuan undertaking!I have the Kindle version of Petersson. It's a pain but it works. I have, I think. five rigging books. Sometimes all of them are different so you just have to pick the most convenient for your situation. I've often thought that maybe just one rigging book would be the answer but then they all leave out some stuff too.![]()
Phil Bolger, the extraordinary boat designer, described his design of the replica of the HMS Rose (1751) in his book "30-Odd Boats." About running rigging, he writes "The running rigging of square-riggers always tended to be changed around with every change of masters. There's a wide choice of unsatisfactory leads, some worse than others. To the best of my knowledge, there's no good way of doing it." The chapter also includes useful sketches of standing and running rigging along with descriptions of each line. The new Rose was launchedin 1970. In 2001 she was modified to portray the HMS Surprise in the movie "Master and Commander: the Far Side of the World." I trust that you all have seen the movie as well as read the entire Aubrey/Maturin series of books by Patrick O'Brian. Which reminds me that Jack Aubrey went on about rigging modifications, especially crosscatharpins, in several of the books.Even different builders in the same nation at the same time period would sometimes do things differently, so when you add different nations and different time periods, a single book to cover it all would be a gargantuan undertaking!
