Additiona correction
You can cut the desired length from that long piece of the finished ladder
Your ladder is looking already much much better.Thanks friends.. I'm starting to understand how to do the stairs... This is the first attempt following the description provided by Ukrainian friends
Grazie amici .. comincio a capire come fare le scale... Questo è il primo tentativo seguendo la descrizione fornita dagli amici ukraini
To buy an already finished ladder is much easier way instead buying the ladder kit.,If all else fails you can take the easy way out and go to most ship model fixtures web sites and buy a ladder kit…
Failures and successes are part of modeling. I started at 14 with the first free flight model airplanes... and stopped at 40 with RC aerobatics. Now at 79 I have started again by discovering the world of static naval modelling. It's a completely different world and I'm discovering day by day the charm of making these little sailing ships.If all else fails you can take the easy way out and go to most ship model fixtures web sites and buy a ladder kit…
Se hai accesso al pero o al bosso o ad un altro legno simile, gli infissi su piccola scala sembrano molto migliori se realizzati con esso. Il tiglio nella maggior parte dei kit si sfalda molto ed è difficile avere bordi puliti e squadrati, anche con la levigatura.
100 % ..... a model from a kit don't have soul.To buy an already finished ladder is much easier way instead buying the ladder kit.,
But then (imho ) you are missing the passion and the satisfaction of modelship building
Well the kits have something. I am working on occre esmeralda and the second planking is kicking my butt. I truly believe it may not have a soul but it sure has a ton of evil spirits!100 % ..... a model from a kit don't have soul.
Hello,If you have a small circular saw you can make the stairs in this way - I guess the photo session is explaing already the different steps
View attachment 442163 View attachment 442164
View attachment 442165 View attachment 442166
In 1:100 it will be hard to make, but maybe possible
