CAF Granado 1/48 PoF Bomb Vessel by Signet
Columbia, SC
There are quite a number of excellent CAF Granado builds posted here (thank goodness for all the insight and help they are providing me), but for my assistance much more than yours, I am posting this build log, trying my hand at this excellent kit and will post the good and the bad here. I'm just a bit concerned that this is above my skill level, but hope that if I treat each small frame and part as its own model, I will eventually complete it. I know a number of others have quit building this kit (surprisingly to me, mostly after completion of Part 1, the main hull outer structure, which I think is the most difficult part), but sincerely hope that will not be the case here, health or other unavoidable issues notwithstanding.
There is no need for me to take photos or talk about opening the kit (I got all 3 parts at once), as Uwe and others have covered that so well. (Thank goodness they do this, because it is so very helpful when deciding what kit to build next.) I will at least show my progress, and where what I do deviates from the norm, as it often does, I will show that along with the result, good or bad. I know upfront I will not be splitting the hull horizontally like Uwe, but hope to provide some visibility of the inside structure and details through cut-out portions of the hull and deck.
Since most all my photos have been, and will be, photographed in my den "workplace", I thought I'd show a couple photos of my den "BG" (Before Granado):
Yes, that's the back and tail of one of our cats at the lower right.
My den obviously serves as my computer room, study, TV room and more, in addition to my hobby room and ship model construction room. It isn't suited well to building models, as I love the furniture and want to protect it, but that's what I have. I also have a corner of the garage with all my power tools in, but that is not as comfortable a place to do fine work and assembly, so that will be done here. The lights atop either end of the hutch help provide light from the back while working, in addition to the ceiling and spot lights.
On to the kit! I ordered it from CAF on March 28, and received it this past Wednesday, April 24, taking longer than usual. I think I hit upon a few snags in the process, like ordering late Thursday, a weekend, then a Chinese holiday, and then UPS decided to lose the package, or at least delay it I guess, rather than lose it. That wasn't a problem - I was required by the Admiral to clean up both my den and the garage before starting any new project anyhow. But eventually, it made it here, in one 18 pound box:
Certainly well packed and protected (even against the kind of rain that soaked my MarisStella Ragusian Carrack when it was delivered, but no rain this time). And naturally, the insides is what I was most interested in:
Unlike Keith and some others, I do not like unopened boxes. While I didn't tear everything apart to make an inventory (suspecting I'd lose more by doing so than doing it later), I did open each box, look at the excellent drawings (less than I expected, but understandable given the excellent 3D diagrams in the instruction booklets) and the included parts. A couple packs had broken open (the brass mortar balls seem to break in most packs I've seen). The mortar and cannon pack also was broken, with barrels strewn around, but I think I got all the mortar pieces including the capslocks. And I'm sure Tom at CAF will help if I end up missing something down the road.
The first thing I did was rough-assemble the keel, and place it on the bedplate of the assembly cradle:
I hadn't thought I needed the thick bottom plank for support, because the entire cage ends up so rigid, but Uwe and Keith convinced me to add it, and I had an extra shelf from my kitchen that I decided to use. I realize now that I will not be completely building the cage before actually using portions of it, so attaching it securely to the base was a good idea:
I followed Uwe's and Keith's normal method of "overkill" in attaching it to the base. It's not going anywhere. And I figure that during construction I can place the entire kit and structure on end, on the floor, to make room for other work.
I will be starting out rather slowly on this. For example, I want to use the stem and stern supports of the cage to locate the pieces, rather than just the plans, assuming they will locate and support the pieces throughout the build, so matching them is most important. CAF also shows dry fitting all the frames to the keel before going further with the cage than I show above.
So, I already have questions:
The basic keel is made up of 3 parts, with a tab of each fitting into the slot of the base of the cage:
Aha - I see I have gotten all the way to Step 1 before asking my first question! Cautious Anyhow, unless the future mounting base has similar slots for these 3 tabs to fit into, which is doubtful, they will have to be removed later. These tabs are 6mm thick, and can just see myself holding a completed and painted model on my lap, trying to carve or cut them away without dropping the model or ruining the finish. Might it be a good idea to cut a groove on each side of the tab as a working line to facilitate later removal? They'd still be strong enough to locate the keel, and once framing starts, they and the stern and stem pieces will hold it as well. Or do you have other suggestions for doing this?
Oh, and not that it matters for the build, but I have rarely seen the Granado referred to as "HMS Granado", despite being a ship in His Majesty's navy. Peter Goodwin's book just refers to it on the title as "The Bomb Vessel Granado", and most text just says "The Granado". As I said, very rarely has it been referred to as HMS Granado, a couple have referenced it as "H.M.B.V. Granado", for His Magesty's Bomb Vessel", but I was just wondering about this. Perhaps since it served a dual purpose, as both a sloop and a bomb vessel?
That's it for today. I hope you will decide to join me on this journey, so I can ask more questions, receive more information and guidance, and in general benefit from all of your experience in my build.
Hello Signat, it's great that you dared to do it. I'm already looking forward to your build and will be delighted to be there.
The more the merrier! Always room for all!
Thanks very much for the encouragement. I think I will need it (already screwed up a bit).
I'll pull up a chair next to Tobias. Good luck with this challenging build!
Paul, didn't I read that you were building this model too? I looked for a build log, but couldn't find it.
Nope. I opted for another POF build. You can use the link in my 'signature.'
Good morning. Beautiful study/den/shipyard. My chair is up in the front row. Enjoy! Cheers Grant
Great start on the build, and good luck with keeping the workspace this clean.
I like your displays, especially the OcCre trains above the desk.
With all the Granado, full and cross sections builds, maybe time to set up a group to locate them all easier.
Yeah, that's what I tell my wife, but she doesn't always listen.
Thanks, it worked out well.
Yeah, I could take over the next lower shelf in the bookcase, but that wouldn't be a great place, I think. I intend to completely plank and finish one side of the Granado, and leave the structure and some of the innards visible on the other, so it would be best in a separate case, probably on my desk or something. My wife is not as nautically-minded (despite being the Admiral), so I'm afraid all my constructions except clocks and music boxes are confined to my den.
Hi. So glad your Granado kit arrived safely and that you're documenting your build in this log. Great start and a very good read. I love your beautiful ''den'' but when you start sanding and fairing the frames, a hell of a lot of dust will be created and it's going to get everywhere. Do you intend to do this in your garage workshop? A very interesting point you made about ''HMS'' Granado. I never thought about that. You're right. From now on I shall refer to her as just the Granado. Very best of luck with your build and l shall be following along with great interest and no doubt see how I should have done things better
Yes, the frames and such will be sanded in the garage. But I still do hand sanding and more minor Dremel sanding in my den, so yeah, that goes all over. ;-)
It's great to have you! I'm sure you can help keep me out of trouble.
Since the 3-pieces of the main keel fit well, I glued them together.
After taking it back up to sand, I realized that it wasn't aligned properly: there was a step in the keel that (obviously) shouldn't have been there. This improperly-focused photo shows the offset or step, worse to the left of the piece:
So, my very first gluing of one piece to the other was screwed up. I was more concerned with keeping everything in place and weighted and clamped down, preventing me from checking the alignment. Not the first time I've done that mistake, but I'll be more careful from now on. You also see in the photo above where I've wet down the two joints to take them apart.
After a bit of fine-tuning of the profiles, and being much more careful about the alignment, I glued the 3-piece keel together again:
It worked better this time. I've really got to be more careful on this model, as I'm sure it requires really close tolerances. The weights I've used here are extra 1 pound weights from a grandfather clock's weights (I've built 3 of them).
I next took a look at the major pieces of the stem area:
Shown prior to any cleanup. The milled pieces require a good bit of cleanup. The laser-cut pieces almost fall out of place, requiring no cutting at all. Of course, I understand and appreciate all the extra work done on the milled pieces - they save a bunch of work and make for more exact shapes.
Rather than try to fit all the stem pieces together at once, I worked up from the bottom forward and up, then the next layer added to it, etc. I felt I could insure a good fit in the cage/template, and match the drawing better, by doing one at a time.
I checked the fit in the template and against the drawing after each addition. I only sanded the "back" side enough to insure good glue adhesion, usually sanding the piece being added-on to insure a decent fit. Here it is at a later stage with more added parts:
The pieces are made well and accurate. Mismatches I've had are caused by too much sanding on my part.
The forward portion of the prow must be tapered somewhat, as shown on the instructions:
That taper is 1mm in about 20mm, or just under 3 degrees on each side. While I liked the idea of slowly sanding it, so as not to over-sand, I'm notoriously off-kilter on such things, so instead used my trusty belt sander (yeah, that's what I said, a huge, belt sander on a fragile prow of this expensive model). Am I daring, or what? Anyhow, to help, I taped off the area to be sanded:
I then used the method below, with my belt sander held in a vise, to sand the profiles:
The dowel at the bottom lifted the piece at an angle, which I initially measured with my digital inclinometer, to approach the intended 3 degrees. After I got it close, I just used the tape and the 4mm wide marks on the prow to determine the taper. In the above pic, I've sanded pretty much to the tape, so that's the required angle. This worked out pretty well. Oh, I got out the figurehead of Hermes and confirmed that 4mm wide at that point would give him the wedgie that he needed to sit stably in his final position. I wasn't smart enough to confirm this ahead of time, but did afterwards, thanking CAF for a correct dimension.
The final piece with all of the external pieces mounted in place came out okay:
I intentionally added grooves or bevels where pieces go together, to emphasize the main pieces (and hopefully to hide too-wide gaps), which should look good after finishing. The main problem is smoothing those V-ed areas so they aren't rough. Still have a bit to go there.
It fits fairly well into the jig:
Any inaccuracies are probably due to my sanding.
Okay, how's CAF doing so far? I'd say really good. The pieces are all accurate and well cut or milled. I do, personally, think it's a shame that they designed the ship to be split at a number of overlapped joints. I have no problem with that where joints would actually occur, but on the above piece, a joint appears across all 4 upper sections. This would never be the case in real life. The first and third pieces, at least, would not be cut there, Possibly more. And it's hard to hide some joints, but not others. Maybe it's better to disguise all of them. But after seeing Uwe's build, I think that most people building this model split horizontally will do as he did - cut a straight line all around. Not try to make over 100 overlapped pieces fit smoothly enough to go together and come apart. And if building split that way, or not doing a split at all, there are a lot more pieces (some of them REALLY tiny) that have to be added, yet really shouldn't exist.
I have already found that the best way to cut out milled pieces is with a small, saw attachment for your razor cutter:
The blade is thin enough to not harm the main piece, strong enough to pierce really thin areas, and allows the gap areas to be sawn easily. Laser-cut pieces don't need anything but your fingers and a bit of care where they're very thin.
If you haven't worked with milled parts, I'll say that some of them are fairly clean, and obvious, as to the final shape. Others, like the part above, are less so. The portion to the right, as well as the left portion of the piece above it, has a kind of "fringe" that has apparently been caused by the CNC cutter. It seems to depend on the grain - on side will look like the right shape, with slight "steps" caused by the cutter passes, while the other side can have tiny thin pieces still in place (the "fringes" I refer to in the above. It really isn't obvious what the shape should be. And you can't really take a blade and cut it off. You have no idea how deep to cut to remove the fringe but not harm the shape. I've found a good start is to take the end of a needle file, and "scratch" most of the fringe off. Just scraping it with the file parallel to the piece will remove most of the fringe, so you can start to see the piece below it, after which normal blades or sanding can be used.
The last part concerning milling is a question, perhaps specific to here, but it's hard to know. Here are photos of the lower left piece above, along with one of the framing pieces that slot into it:
Basically, the cross pieces have a slot that fits over the end piece, inserting as shown in the arrow, and the double-arrows show the opening and thickness of the piece at that point. The opening is just under 3.5mm. The thickness of the piece it is to slip over, at the areas marked in red, is about 4.5mm. It obviously, won't fit without modification. But behind that is a groove about 3.7mm thick, shown by the straight blue line. So should I increase the groove to fit over the 4.5mm, or shave off the 4.5mm areas to match the groove behind it, and not modify the cross pieces.
I realize this is such a simplistic statement - if something doesn't fit, you just modify one or the other part until it does, right? But the tolerances on this model are all so close, I fear, and exact placement is so important, that I feel it best to ask the question now, rather than just start making changes and live with the possible consequences.
BTW, I realized after making these measurements, and examining the other pieces 5L-1 to 5L-4 that also fit into the slots, that I chose the wrong location for the above 5K piece, which should go at the very top. Turns out it was already sized correctly, and now I've made a big groove to fit, so will have to do something to fix that problem. But for the other 4 pieces, as shown in the diagram above, the question still stands. They don't fit, so which to modify?
Thanks for reading and watching, I appreciate it. Obviously, more to follow.
I hadn't heard anything back about my question concerning the keel "tabs" that insert into the base of the building jig, so went ahead and put a cut into each at the bottom of the keel, about 1/4 of the keel width in depth, on each side:
I assume these will eventually get cut off, so this will give me a good guide of where to cut, and give a good start to that cut. In the meantime, there's enough meat on it to hold the keel into the jig.
It's kind of wild that the 3D milled pieces can end up looking like they should (hopefully):
It is a little hard, sometimes, to know exactly what the exact shape of the edges should be. I used a sanding bit on a Dremel on the insides of these, which changed the contour. Hopefully, that's not a problem. Also, I've gone ahead and, in general, widened the grooves in the above pieces, rather than reducing the width of the mating part.
I decided it was about time to glue the stem to the keel. (I'd been avoiding that, because the keel will be come end-heavy once the stem and stern are attached, but hopefully I won't break it.)
I'll be keeping everything in this position until most of the deadwood and other material is added above both stem, stern and keel, reinforcing them.
I then glued the end of the stern in place (sorry for all these non-nautical terms):
Uwe, and maybe others, will see that I've invested in some Ponal Express glue for most of this kit. I'm pretty happy with it, and only use Titebond Quick & Thick where I have larger gaps to fill.
Then the stern deadwood that helps reinforce that area:
And finally the deadwood and such above both ends, as well as the keel add-ons that locate the frames:
This will all reinforce the connection of the stem and stern to the keel, hopefully keeping me from breaking it (and, of course, necessary for the model assembly).
As I want this assembly to dry overnight, I made up next the supporting pieces that go on each end for the frames at each end. Here, the stem set is done, while the stern is still in place:
Hard to believe it's possible to get the right pieces out of these. After cutting out with the saw posted above:
But after shaping, we have something reasonable, albeit thin and a bit fragile):
I thought they were about done, but now looking at the photos, I see that I still have sanding to do. My eyes just don't pick up on this.
BTW, I realize, from my posts here at SoS, that a blue cutting board cannot produce a quality model (the reason my Ragusian Carrack does not match Olha's, of course :rolleyes: ). So, I've asked for a new green cutting board for my birthday in a little over a week. I'm sure you will see a huge improvement in my modeling at that time!
Well, I said those parts are fragile. I see that the upper-right part in the photo above is missing a step, as it's supposed to be a mirror image of the one below it. It isn't in the block it was cut from, and I see from other photos above it was missing early on. Apparently removed during my over-zealous cleanup process. It is the smallest step, so rather than try to add a piece on, make a new one or ask CAF to supply a new one, I'm going to use it as-is, and just try to mount the frame above in the correct position, then look to see if I need to fill in with something.
Speaking of those parts, the pair located at the stern (8A-1) are shown located thus:
Shown located along a curved line. But that line does not exist on the parts. So I made a copy of this area of the plans side view, cut it out and traced a pencil line to locate the part. I think that will work out.
Looking now at the 5 cross pieces that mount on the stern, trying to decide the order to mount parts. I think this is best done before going further with the jig, at least partially:
I don't see how I can "Pre assemble" this entire structure and place it in the dock (not jig, as I see in the above, but I may use both). I can see gluing 5K and 5L-1 to -4 in place, then fitting it into the dock, seeing how 53# fits, sanding the assembly and trying again until it fits.
Very good work and progress
Ponal Express glue -> Bravo for this decision - I am using it since years
Green cutting mat -> best decision ever -> Your Granado will be the best model
Continuing on, here is the completed keel assembly at this point:
After placing the pieces to the sides of the ends, I went ahead and prepared the crossmembers at the stern:
After a bit more finishing, I glued them on to the stern:
These pieces have about a 1mm gap between them, so I used scrap pieces of 1mm stock to keep them separate. Not shown, I used a clamp to support the bottom-most piece while it cured, then added the rest.
After the glue was dry, scraps were removed and we have:
I then glued together the two pieces of ribs #53, but didn't take a photo of them.
I decided to go ahead and make one of the frames, starting with double frame #10, as outlined in the instructions. To help align the bottom of the frame layers, I used a piece of scrap from the keel wood, which is a good fit to both slots.
This procedure mostly follows Uwe's procedure, using Fixogum to hold pieces in place and Ponal Express glue (which I'm really starting to love).
I used a combination of a 1/2" wide hand belt sander, Dremel drum sander and hand sanding on the frame pieces made thus far:
And here is frame #10 positioned in place:
I'm finding that the frames do not fit over the keel into the depressions milled for them. The openings are not wide enough. Widening the openings is very difficult in these mortised areas, so I sanded the bottom of the frame on each side until it fit. As long as it's centered and it the correct location I don't think the thinner frame at this point will matter.
I'll probably go ahead and make most if not all frames before putting the jig/dock together. That's what the instructions show, testing the frames for fit onto the keel with completely open access is available without the sides of the dock. So I may not post much about that, as it will be a combination of the frames already shown. I figure I may get 1 frame, maybe 2, in a day, so need to get working on them.
Thanks for the comments and all the likes! Until next time!
Continuing on with work on the various frames:
As well as fore half frames. By using extra pieces of 1mm and 2mm scrap to create spacers, I was able to work on as many as 4 frames at once:
In all cases, I allow the frame pieces to dry overnight before removing them and doing the required sanding.
In most cases, the height of the frames exceeds what is shown on the full size templates. I wasn't concerned about that, and in fact prefer to leave extra at the top to be sanding straight/curved later. But where gunports or oar ports are located, I felt the height needed to be right on. This required removal of some material as shown here before removal:
Yes, they could probably be sanded to the right height later, but I prefer to do them during assembly. After trimming to the correct height for the oar holes shown above, which are also used to insure correct height of the frames within the jig, I inserted a piece of the 4x4mm strip to insure straight and accurate location:
Now to a problem that everyone building this kit will have to solve, I believe. The width of the frames (single, double and triple) are too wide to fit in the milled "notches" at the top of the keel. I tried several methods of fixing this:
First, I sanded the bottom of the frame at the notch level to fit. This resulted in a curved frame at the bottom, which I didn't like (sorry, frame #10, you were the guinea pig). Then I tried opening up the area between the ribs to allow the frames to fit. I tried this on frames 8 and 9, both double frames. This worked, but took a while, removing the keel assembly, and tried several ways of doing this, including a $700 Wondercutter X which I thought would be ideal for this. It wasn't (and since I found no to other areas in which it excelled, I returned it). That eventually worked, but was hard to control and do accurately.
My last method involved removing a quarter-circle of material at the top of the notch. That worked well for me, and I'll be doing the rest of them that way. Here is shown an un-sanded frame component, fitting just fine over the area between the ribs on the keel assembly:
As you can see, the precut opening works just fine vertically and horizontally, but as I said, the frames are too thick to go in between longitudinally. This photo shows the frame piece "hung up" on the ribs:
Yes, I didn't position it exactly right, but unless the distance between the ribs is equal to or greater than the frame thickness, it just doesn't go.
What I arrived at was using a small milling cutter in a Dremel an relieving the outer thickness of the frame (single, double or triple, doesn't matter), decreasing the thickness of the frame only at the point of the ribs:
The total amount to be removed is just over 1mm total, so a half mm either side or a bit more lets the frame nestle into place:
Yes, the horizontal distance might be off by a quarter mm or probably less, but can be centered by eye, and I prefer this method.
Incidentally, I had problems with my existing files in removing char and tapering the notches in the frames that fit over the keel assembly. I ended up buying a set of Perma-Grit files from Amazon. Yes, they are too coarse to use for many purposes, but remove material and char extremely well, and I actually prefer the rough finish when two mating parts are glued together; it provides "tooth" for the glue and makes a very strong bond.
I decided next to break up my frame making by working on the bow assemblies for the model:
QUESTION/PROBLEM: This one has me a bit confused, though. There are spacers between most of these pieces that keep them separated and connected, like this:
These pieces are shown in red. Well, like many pieces in the frame, they have laser lines which usually mean a bevel is to be sanded to shape the piece. But as shown in the photo below, those lines, when they exist, don't seem to do that:
The pieces being discussed are shown to the right of their associated ribs. 3 of the 4 have laser lines, the 4th does not. And when they are placed to match the curve of the ribs, the laser lines seems to be on the wrong side. They basically make no sense to me. Perhaps someone can enlighten me on this?
Also, the drawing above shows the spacers keeping the ribs apart at 2mm, but somehow looks like they touch each other at the "pointy" end. Uwek's build shows this:
Should the "shims" between each frame be sanded and tapered to achieve this? Keef's assembly does not seem to indicate this:
As always, thanks for reading. Hope someone can give me a bit of advice here. It may not matter, as the assembly seems like it will go together okay, but those lines are meant for something!
I meant to include this pic last time, showing the Perma-Grit needle files I've been using:
Yes, they're pretty rough, but remove material quickly, don't clog and the rough finish helps with glue adhesion. And yes, I'll use finer grit needle files for finer work.
I think I understand the assembly of the bow pieces mentioned above better now, so continued with them. Here are the first two pieces, glued to each other, but the lower piece only glued in place with rubber cement:
After adding the next shim, and while trying to shape/taper it, I found the rubber cement didn't really hold (I didn't use enough or wait long enough). But I then found I could do sanding to the assembly, and put it back into the jig, without any apparent loss of accuracy:
The completed assembly has zero gaps at the end of the first couple frames, more at the top, and is shown pretty well on the front view of the plans:
Likewise with the other side:
After sanding the shim strips, etc. and trial placing them onto ribs #1, the don't look too bad:
Like the other frames, I've sanded the inside surfaces with sandpaper up to 240 grit, hoping to not have to do much sanding after assembly. The outer surface, however, has been left pretty rough, because I know I will have to sand them.
If I'd do anything different here than I did, it would be to leave more stock on (beyond the laser lines) for final shaping, maybe not even remove the outer char. Hopefully, these will be even enough for a final shape and planking.
Finally, a progress photo of where I am in assembling and sanding the ribs and such, along with my new green cutting mat (also shown above), which is much greener than my photos are coming out:
Hopefully, my work will improve now that I'm using a green mat. I can hope, can't I?
I've been working steadily on all of the frames for the model. Here is where I am at the moment:
My general procedure for each frame is:
  • Assemble using Uwe's FixoGum & Ponal method over the full size template, and let dry overnight.
    Hint: Do NOT assume that a given frame set of parts (A, B & C) all use the same side of the sheet; some have to be flipped over, showing the somewhat ugly burned side, to have the proper laser bevel marks on them.
  • File the slot that goes over the keel to fit. For all but triple frames, I test fit them over a triple frame slot, then route the ends to fit within the keel slots (described in detail in post #18 above).
  • I use a 1/2"x18" Variable Speed Detailing File Sander to shape the bevels on the inside and outside. This takes off material fairly quickly (at the lowest speed), and makes for a pretty straight bevel. I haven't slipped TOO much, so most of the profiles are okay.
  • I then use a Dremel with a sanding drum to get rid of the cross-sanding lines and fine tune the profile.
  • Finally, I hand sand the inside profiles up to 180 grit sandpaper, giving a reasonably smooth finish, which I hope to not have to alter. The outer surface is left rough, because I know I will have to blend and modify them.
I'll be assembling frame numbers 38 and 39 tonight. I had held off on them due to some errors in the part identification drawings. I'll post here the corrections that I have found (corrections are shown in blue):
This pic shows a similar change:
but also shows the fact that part 36a-3 is provided in 2 different places, in 3mm thickness and also in 4mm thickness. I used the 4mm thickness, having only found out tonight about the duplicate. This frame is on one side of a gunport, and the pieces in question actually support the gunport sill. I don't see where it will hurt anything using the 4mm pieces, but think the 3mm is what was really intended. I mostly wanted you to realize there is a duplicate, and you will not use one set of these pieces in your model, so don't have a near-heart-attack, like I did!
That's it for tonight. Gotta get working on #38 and 39, now that I have the numbers worked out.
