YQ Bluenose Ted R (COM PLETED)
You can't leave it out or too long; once you're at the step of installing longerons 102 and 103 they need to be in.
(I think I at least broke three of these spider legs, before covering up...)
Ok, I'll finish the sanding/fairing and then install them. Probably going to be a lot of manipulation of the hull getting mine straightened out.
I would say that is your wisest choice, Ted. I found out the hard way this ship is very unforgiving when you start building her out of her very tight tolerances.
I removed frame 13 to move it up a little. Of course I broke one of the legs. This is perfect reinforcement for doing it accurately the first time. I didn't really understand all of the parameters I should have been tracking during the first install. You can bet that is a lesson I won't forget.
Photo of the leg b1714340270249850686562798289113.jpgeing glued.
Photo of the leg bView attachment 444458eing glued.
Thank you. Thus is a demanding past time isn't it
And another member for the BFC (Broken Frame Club)!
I think the best thing to do is to read the instructions and drawings carefully and to try and be four or five steps ahead in your mind from where youu're actually at. Oh, and going through build logs from others, that is immensely illuminating.
I agree, I'm constantly reading build logs. They are a guiding light for this project. The misaligned errors I m making are fairly small but an indication of my lack of experience. I've learned more about ship modeling from this kit than I had previously. My total experience is at about 5 months at this point. However I am not daunted by what lies ahead.
I am going through realigning the frames at this point. I am not quite sure what an acceptable discrepancy is allowable and should be left for sanding.
Once again, I want to thank you gentlemen for your guidance and assistance. It's invaluable
Ted
I have the frames aligned almost perfectly using a planking strip. I'm seeing that the notches don't fall in line at the center. But work in a sweeping manner otherwise. Should these frames be moved up to fall in line. Or should some other modification be done.View attachment 444750View attachment 444751View attachment 444749
Hi Ted. That is looking much better. Check also if the top of the frames are flat with the bottom/underside of the jig. Perhaps that with align the notches.
The notches have a discrete step at frame 27, if memory serves me correctly. The step is from the fore- to the quarterdeck. The notches of the fore deck should have their own upward sweeping curve towards the bow, while the notches, belonging to the quarter deck frames should sweep upwards towards the stern. Both curves should show a smooth curvature, although some variation is inevitable. Also, at the keel, the lower edges of the frames should form a smooth conti curve over the entire length of the keel. See the attached picture.
Thanks, I'll spend some time with looking for a correlation between the frame misalignment and flush with the bottom of the jig
Here's a photo of the bottom of the jig. I found no correlation between the frames that are not flush with the bottom of the jig and misaligned at the deck level notch. Some that are perfectly flat at the bottom and in fairing are the ones out of alignment at the notch level. Maybe not perfectly assembled as a frame?
At this point I have become frustrated. I'm going to build something else like a piece of deck furniture while I try to figure out if I have to remove all the frames and start over.
Thank you for the birthday card.
Ted
TedView attachment 444838
Check each and every frame and the keel against the drawings. That should give you some insights.
Hi Ted, unfortunately frustration is also a part of model building at this level. When I get frustrated (which is common with me), I will take a break from the build sometimes for a good while then come back to it with a much-improved attitude. My bet is just about every one of us on this forum has experienced frustration at some point, I hope you come back to it when the time is right.
