Sent you a copy by PM. Indeed, a must-read for your project
Hi Stephan,Hallo Waldemar, can you name the source of the so-called Newton manuscript from the second quarter of the 17th century? The paper is often mentioned, but always without a source.
Thank you very much
Stephan
Hi Ondras,Hello Marten. I am following your interesting project, I will continue to follow. There was a discussion about this ship years ago on the Czech forum. Maybe some link will be useful for you. Fingers crossed, Ondras
Diskusní fórum modelářů • Přihlásit se
www.modelforum.cz
Old drawings, new 3D and basic math, you make a nice combination of them, Maarten.As we have seen in the previous post projecting the center on top the Lely painting the wider top timber / less tumble home of Dean & Bushnell seems to fit the picture better then the smaller top timber width of the 1620 treatise.
The Newton manuscript however mentions a top timber width reaching from the smaller 1620 treatise value towards the larger Dean values or between 2/3 bm to 4/5 bm for SotS this is between 31' to 37' 2".
To counter check the Lely painting wider top timber width I will compare it with the measured width in the Van de Velde Morgan drawing. However the Morgan drawing is made at an angle and I first have to determine the angle.
To do this I have scaled the morgan drawing to the Boston drawing in height reference points.
I also have put both drawings on top of each other in Fusion to scale the Van de Velde drawing to the Boston drawing.
After that I measured both drawing over the same horizontal reference points. The Boston drawing is 232 ft, the Morgan drawing +/-160 ft.
Dividing these gives nearly the square root of 2 which means the ship is drawn at a nearly 45 deg angle.
With this I can measure the width of the top timber on the main deck.
Measuring around 26' at a 45 deg angle or 1,41 x 26 = 36'9" and very close to the wider deck of the Newton manuscript and the Dean value.
It seems or Pett design had a wide top timber design which seems reasonable to make space for the upper gun decks. Petts larger frame radius above the bm also acknowledges this.
So I have redrawn the center frame using the larger Dean/Newton document top timber width, reconstructed the decks using data handed over from the navy archives and plotted the frame at a 45 deg angle on top of the Morgan drawing.
Te data seems to be very close. The decks do fit, the gun ports fit, the waterline fits, the angle of the lower gun ports is very close. It only looks the angle of the gun ports on the second gun deck are too much upright allthough the entrance port is again pretty close.
Sofar I wil go for the wider top timber/ deck space as mentioned in the Newton manuscript, in Dean and Bushnell.
Maybe I will retest a smaller radius for the top timber sweep to get a closer fit for the second gun deck port angle. Also I will make a comparison on the other Van de Velde drawings of the ship to double check the comparison, but that will be next time.
Hi Marc,This is a fascinating study in reverse-engineering, Maarten. I love all versions of the Sovereign, but the first re-build Sovereign is my favorite.
An interesting post, Maarten. I'm curious about the 1st perspective prints.Work continues on the SotS.
Over the last months I have been reading all the available manuscripts and also @Waldemar very interesting blog of the O3 model. https://shipsofscale.com/sosforums/threads/naseby-1655-reverse-engineering-the-ship-model.11841/
The O3 model as made by Francis Sheldon in the late 1650's to solicitate at the Swedish court to become the new navy shipwright.
The very interesting about Francis Sheldon is that he was an apprentice of Peter Pett who actually build the SotS. Closer we can't get to his work then this.
In his blog Waldemar also compares the O3 model to the ratios of the hms Naseby or later Royal Charles, being a very close fit in ratios at a different scale. The original HMS Naseby was build by Peter Pett and Francis Sheldon working for Peter Pett on this build.
I compared the center frame of the O3 model to the lower part of the SotS center frame and these are pretty close in design. I will post this comparison later.
This gave me the idea to create a hull for SotS based on the ratios as given for the O3 model and see what the result is.
I will try to explain as much as possible the steps of how to create a hull from the provided data.
To start with the line of greatest breadth.
The line of greatest breadth is exactly what is says and showing the greatest breadth of the ship along the hull. This is a 3d shape with a top view and a side view together creating a 3d line.
Today the top view aft side of this line.
As the blog of Waldemar shows on the O3 model this top view aft is created by a mezzoluna transformation. This is not a simple arc but an arc with a constant changing radius.
To create this mezzoluna I first have to determine the timber and space on my ship.
The timber and space is the thickness of the frame and the space between the frames which was normally the same as te thickness of a frame in a war ship.
From the center frame at 1/3 of the keel from the front or 2/3 from the stern I can place 34 frames towards the stern from the center frame.
This is 2/3 x 127 foot = 84 2/3 foot / 34 = 2 1/2 foot timber and space. This means my floors will be 1 1/4 foot thick.
So I have to devide my complete ship in parts of 2 1/2 foot of which I want to draw every third frame in full scale.
You can see that below.
The midship section of the top view line of greatest breadth on the O3 model is straight over 8 frames for the center and aft of the center frame. So I start with a straight line over 8 frames from center frame towards the stern.
To create the mezzoluna you draw half a circle behind the ship with the same breadth as the hull. For the SotS this is 46,5 ft or a radius if 23,25 ft.
In this half circle you have to draw the width of the transome, the widest point of the hull in the stern. For SotS this is 28 ft.
I draw a circle of 14ft radius to cross the half circle at its center line. My transome is now set.
Now I have to devide the space between the transome and the center line of the half circle by the number of frames I want to draw proportionally to the frames in the aft end of the ship.
For these points I draw vertical lines to cross the circle. The crossing of the circle determines the breadth of the ship at that specific frame.
By drawing horizontal lines towards the corresponding frames I create the shape of the hull at maximum breadth for the top view.
Now these created points can be connected with each other by using tangent arc lines, every tangent arc line has a slightly different radius.
What is the difference with a regular arc you can see below. The mezzoluna in blue, the single arc in green.
The mezzoluna creates a wider hull towards the stern creating more bouyancy in the stern of the ship.
Next time the fwd part of the line of greatest breadth.
The current perspective is now only the keel, stem stern and center frame. But the shape is growingAn interesting post, Maarten. I'm curious about the 1st perspective prints.
Hi Tobias,Martin, I'm very impressed. For me, these are Bohemian villages, which makes them all the more interesting to me. Simply great.
Hi Christian,Does Fusion has a 3D spline? I tried to draw something similiar with Rhino, but find it rally difficult. I can easier work with the profile view,
Perhaps I should give this another try.
