Does anyone know who the manufacturer of this tool is? Or where it's manufactured? Micro Mark offers no response to my many inquiries. This unit has a belt drive from the motor to the drum. I want to get an OEM belt.
the belt for the thickness sander is a bit different in shape and your suggestion simply wouldn't wokToday it is not necessary to buy brand name replacement power transmission belts. I suggest buying this product per link below. This material is cut to length and ends are welded together with heat. Different diameters are also available. Also nothing prevents using a few of them instead of some flat belts. I use this on my Unimat DB lathe. I will explain how to weld ends together if anyone is interested.
Your belt brand is Bando. It is called a Transmission beltI found the label on the belt. "3PJ353" I Googled it and found the belt only in VieNam. Mine is on it's last leg. Anyone who can give me a lead in North America I'd appreciate it.
I bought this unit used:
- The plate was severely gouged by the sanding drum. I was able to flip it over and use the bottom as the top. Ultimately I will have a machine shop weld fill the gouge and mill it flat.
- I have a devil of a time putting a new sleeve. Tried powders, grease and voodoo. Freezing the drum works the best.
- I am able to buy drums from Grizzly for about $12 for 3. I found 80 grit is the best and most durable. Higher grit does not produce a better finish on cherry. I only pass thru about 2" slats so I can use three pass lanes over the drum.
- It only takes off about .01 a pass. Much more trips the internal circuit breaker. I'd like to investigate a more powerful motor. It's a ZYT150 a pretty expensive piece.
- Once the table is leveled it's accurate.
| Type | V belts |
| Belt trade size | PJ |
| System of measurement | Metric |
| Belt length | 353mm |
| Belt width | 7.02mm |
| Belt thickness | 3.4mm |
| Belt angle | 40° |
| Minimum pulley diameter | 20mm |
| Belt material | Rubber |
| V-Belt Type | Banded |
| V-rib pitch | 2.34mm |
| Number of ribs | 3 |
| V-rib thickness | 1.3mm |
| Color | Black |
| Load | 0.75kW or less |
| Highest speed | 50m/s |
| Application properties | Highspeed, Smooth operation |
| Operation ambient | Flame resistance, Weather resistance, Heat resistance, Oil resistance, Water resistance |
| Operating temperature | -30...90°C |
www.bandousa.com
This is great news, Bill. Please post the part number or better the Amazon link here, so it will help others. Many of our members use MicrosLux sander.Well, there is always someone that knows. Contacted Bando this morning. They responded with their p/n and a list of local distributors. Found the part on Amazon for 7 bucks. Thanks!!
Hello,
That would be Bando part number : 140J3
Please provide your zip code and I can refer you to a distributor.
Bando does not sell direct.
Best Regards,
Jessica Hilderbrand
Service Express
Bando USA, Inc
Email- jessica.hilderbrand@bandogrp.com
Office: 630-773-6600
