I use a 1.5 mm chip drill bit to cut through the gun ports. With the help of a diamond disc, I made a slot so that two teeth turned out at the end of the drill. Such an improvised milling cutter cuts wood quite smartly.First time builder looking for best options for cutting gun ports in solid hull?
You missed the bit where it says solid hull.If you know where they belong before you start the planking, there are two option I have seen used.
1. Plank over the location and drill out with bit smaller than hole so you can carve or file to final shape and location.
2. If you have wood template with openings as you plank over them, as plank reaches a port hole, cut out half of the hole in first plank, and then when you add the next row you can then cut out the other part of the opening with exacto blade.
Why would that be necessary or desirable?First time builder looking for best options for cutting gun ports in solid hull?
Which model are you building? Could you post pictures of the hull you are working with? I assume when you say "solid" you mean it is not hollow on the inside.First time builder looking for best options for cutting gun ports in solid hull?
You mean a carved out hole which is cut square, I assume.Most solid hulls have just black paint for hole and stub barrel sticking out.
