Will someone explain to me the differences among these? From my looking the yards may have one or more of them and they all seem to do the same thing. Puzzled (as usual
Hi Steel,A tie is a piece of rope on your sail where you can tie the sail up (reefing of the sails)
Exactly! All books I have are like this. I guess we have to figure it out on our own. My guess is the jeers on lower mast are for lowering and raising the lower mast yard. The sling on same yard is a redundant safety feature if jeers brake down. On top mast yard they have only the TYE rope with block which is same as jeers for lowering and raising the yard but they did not bother here with safety as much as this yard is not that heavy and important as a lower mast yard. So they had no redundant safety as a SLING on lower yard.Lees book and while it is an excellent source it is like all the others. It tells you where the rope goes but it doesn't tell you what it does.
With respect to the hoisting of the yard aloft, jeers or a halyard/tie are used to get it there, and slings are there to guarantee that it stays there. Let's say you want to work underneath your car and fix the exhaust system. The hydraulic lift is used to raise it so you can get underneath it, but the jackstands are there to make sure it stays up there and doesn't fall on you if the lift fails. You want both.I am also confused. Why we need a SLING and JEERS. They both serve same function and are on same yard. Sling is of a permanent length so it is not adjustable. Jeers is a sling with blocks. Could some one please explain?
Looking at pictures above is true for a lower mast yard. On top mast yard the jeers is called a TYE. They do not have a SLING on top mast yard. WHY is sling present on low mast yard and is not present on top mast yard? Yet another mystery.
Thanks. Do you know why only lower mast yard has a sling but upper yards don’t?, and slings are there to guarantee that it stays there.
Probably because they are much lighter and easier to handle using manpower. The course yards are REALLY heavy.Thanks. Do you know why only lower mast yard has a sling but upper yards don’t?
I understand your confusion. The word tie in English can mean different things depending on the context. In the case I was using above, a method of hoisting a yardarm used in earlier continental European ships was the tie and halyard. The tie is the line from the yardarm over masthead and down to the upper block of the tackle below. In some ships, the ties went through sheaves in the mast just below the top, as in the example below. The halyard is the line in the tackle, which is secured to the timberhead. On the course sail yards, there are two ties. On lighter yards up higher and on the lateen yard, there is one.The problem is the year you talking about. 18th and 19th century. Is very different to earlier ages. Especially in Dutch language. I don't understand the English name tie. For me a tie is like a piece of rope used to make a knot and secure it. Like reefbands.
Or something like I marked. You have also the plastic thing called tie-wrap.
But Learning again something. A tie kan be the same thing as halyard to lower and hoist a mast.
Slings ans jeers I know, Kurt describe them perfect with the car to understand the difference.
Names in rigging can confuse sometimes.
Great explanation. Also, keep in mind that the sling was made of rope when at peace. In the event of war/battles these were replaced with chain to reduce the likelihood that the sling could be shot away. I believe it was about 1870 that all slings were chain, not rope.With respect to the hoisting of the yard aloft, jeers or a halyard/tie are used to get it there, and slings are there to guarantee that it stays there.
Great question. Just a guess to add to the conversation as to why...... the topsail yards, top gallant yards and royals were lowered at times when in port. If there were slings, they would have to be unrigged. Then again I found this reference to slings in Steel's The Elements and Practice of Rigging on page 204:Do you know why only lower mast yard has a sling but upper yards don’t?
