- Jul 21, 2021
Hmmm. Unfortunately, I wasn't patient enough to wait for a reply. I used a brass rod, but I used a tiny amount of JB Weld, which I'm hoping will offset the flexibility of the brass. It's in a spot that is difficult to see, so I'm not worried about the gray glue color. The brass rod gave me the ability to make adjustments so that the mast would be straight.Drill both ends and glue in a pin - a 1 inch panel pin would suffice, but cut the head off first. Don't use brass rod because it may bend when rigging.
I hope it works out for you. Regards.Hmmm. Unfortunately, I wasn't patient enough to wait for a reply. I used a brass rod, but I used a tiny amount of JB Weld, which I'm hoping will offset the flexibility of the brass. It's in a spot that is difficult to see, so I'm not worried about the gray glue color. The brass rod gave me the ability to make adjustments so that the mast would be straight.
That will probably work fine. Another approach that I have used to repair breaks of this sort, including larger ones like chair legs, is:Hmmm. Unfortunately, I wasn't patient enough to wait for a reply. I used a brass rod, but I used a tiny amount of JB Weld, which I'm hoping will offset the flexibility of the brass. It's in a spot that is difficult to see, so I'm not worried about the gray glue color. The brass rod gave me the ability to make adjustments so that the mast would be straight.
Thanks. I'll keep that in mind for the future. Fortunately, my idea worked and the mast is very solid. JB Weld is a lifesaver.That will probably work fine. Another approach that I have used to repair breaks of this sort, including larger ones like chair legs, is:
Fair winds!
- Choose an appropriate dowel or, in this case, a toothpick to join the two pieces
- Drill holes in both pieces a little larger in diameter than the dowel (this will allow adjustments to the alignment)
- Use epoxy glue (like JB Weld) to fasten the joint
- Support the joint in the appropriate alignment until set
Hi, are you referring to stepping the masts in the deck? If so, I agree, that gives you flexibility in assuring everything is properly aligned.An advice:
Never glue the masts to the holes.
Surround them with strips of cardstock until they fit snugly.
Then with the rigging, they won't move.
You can make two small holes with the DREMMEL and insert a piece of
piano wire of the appropriate thickness, which will also serve as a drill bit.
Then glue with Titebond or similar
Regards
I prefer using wood in lieu of metal for this type of repair where feasible, as described in my earlier post (#5). This eliminates the concern with the metal pin bending, as well as making alignment easier. Of course the wood pin has to be strong enough to withstand the forces of the rigging. With the joint glued with epoxy, this is seldom an issue.I think I would do exactly as the OP has... with the exception of using a piece of steel rod, or a long finishing nail with the head cut off. I do have brass rod that is extremely stiff, so depending upon what type of brass rod was used, it too should be okay. The key, as noted by others is to brace and clamp till set to assure straightness, and then to carefully manage the tension of standing rigging to ensure it doesn't get pulled out of alignment. I too would be heartbroken if that had happened to me, but I think you found a good, workable solution. I wish you success in the rest of your build.
![20240715_192612[1].jpg 20240715_192612[1].jpg](https://shipsofscale.com/sosforums/data/attachments/443/443177-6f9c3136c48c1b1b9424939b4a881d72.jpg?hash=b5wxNsSMGx)
