Charles Mower design #22 - a new approach to kit design
Montreal, Canada
I am working on a redesign of one of my frame sets and thought you might all get a kick out of a new approach I am taking.
In this design, the shape is created in a dedicated software that works well with organic shapes and then that part is inserted in one of the "usual suspects" for CAD for manufacturing.
But that is not important. What is fun is the resulting details that I have been able to introduce to contemporary kit design.
In this case, I have done the following:
- doubled the number of frames that were in the original drawing. Remember, since I am working off of a 3D hull shape, I can add bulkheads wherever I want, and in any orientation.
- opened up the cockpit area in preparation for including seats, fixed and 3D-printed, as part of the kit
- added stringers to give the model builder a more accurate, and enjoyable, build.
This is an ongoing project. I will add a few more pictures later, as I get closer to cutting the parts.
Hello All!
It's been a while since I posted what I have done with this model. I am surprised to see it has been more than a month!
Well, getting those stretchers to line up nicely was quite a challenge. I have to say, there's probable a solid twenty hours that went into trying a variety of features in the software to get this right.
The difficulties come from two things. First, the software doesn't "know" that I am cutting these parts from 3mm plywood. The second is that a hull shape does not twist evenly from the stern to the bow.
For the first issue, one cannot simply send a "cut" along some path to cut the notches in the frames. Such a path would follow a 3D shape and would cut the frames precisely along that path. That sounds nice but, of course, we don't cut the frames in 3D. They are cut on a laser on a flat surface. So, if we simply send a cut in 3D, when we lay the parts on the cutting table, the laser will see a whole bunch of lines where the cut goes through at some weird angle.
So, I had to figure out how to get that path to work, but the laser to know where to cut so the builder can install the stringers with the least amount of fiddling. Obviously, the builder will have to to some sanding to get the stringer to follow the shape of the hull, but the idea is to keep that to a minimum.
Also, when I did the first "insertion" of the stringers, they simply did not look realistic. I went through many, many iterations to get the look I wanted.
Now, we have a wonderful, revolutionary, method of designing and fabricating boat hulls!
I do not know how to rearrange the photos once they are inserted in the post. Can it be done?
In this first picture, we see a couple of these "cuts" that the software will do easily enough, but that do not work for what we are trying to achieve.
In this second photo we can see the insertion of the sheer plank. The software will twist the plank along the path, but the twist is "even" all the way along, which is incorrect for a boat sheer plank. We need to figure out another solution.
This picture is a bit out of order. It shows the stringers in place, with the notches all done, and it also shows a garboard strake that I have added. This plank does two things. First, it acts as a "landing pad" for the lower planks and it also strengthens the keel considerably.
Another picture that is out of place. I am now building up the internal surfaces of the model. Here you can see the rear seat installed.
The picture below is an interim picture. I was certainly not happy with the stringers following waterlines. That just didn't seem right, or realistic. I tried a number of strategies to work the stringers into a realistic arrangement.
Finally, the stringers look pretty good!
Here is a nice bow-on view. You can see the smooth curves that the stringers will make once you build this model.
This picture show how many lines the laser would be looking at if we just used the cut path that the software wanted to use. I had to find a completely different strategy to make the cuts work properly.
Looks like you are getting it figured out and shaped up good.
It will be nice to see the boat when actually printed and assembled.
I have continued the design of this model. I now have some parts designed that will be 3D-printed and I have started the design of the T-rail. At 42", this will be a good model for those of us whose eyesight is weakening (and for those who want their models to go in the water).
The first picture shows the T-rail positioning on your workbench. The second picture shows port and starboard bow chocks. The third picture shows the rear bench. The cushion will be up to you!
Now that I doing the laser-cutting layout, I am looking at various 2D views of the model. This picture really shows the interesting, twisting, notches for the stringers. Note the notches on the starboard side, and my 3D "stringers" on the port side. The basic kit does not include planking, although it does include several 3D-printed parts.
The picture also shows one of the parts of the cradle that will come with the kit. Since I design the cradles right off the 3D model, they fit very nicely.
Rick, are you able to describe the problem with the stringer notches a bit more, and what you did to work around this?
Hi Rick,
My post is no longer likely to help you, as you have actually solved yourself the problems associated with longitudinal battens notched into bulkheads. Nevertheless, let me show a similar solution used by professional museum modellers when building a 1627 ship model of my design.
I have provided them with hull cross sections in PDF format as in the example graphic attached below. Among other things, wales are always drawn on each cross section. The modellers, on their own initiative, took advantage of this circumstance by adding notches in the bulkheads for the wales (the latter had to be suitably thickened to accommodate this recessing).
It was only when the contours of the bulkheads had been modified by modellers in this way, still in the graphics program, that the final PDF files were submitted for CNC cutting into the plywood (strictly speaking, these were cut on a CNC milling machine, not on a laser cutter, but the perpendicularity of the cut to the table (and consequently to the flat material) is the same). One can partly see these recessed wales and notches they added in the attached photograph of the model under construction, although perhaps not very clearly.
I don't know how they took into account the inevitable perpendicularity (verticality) of cut in relation to the, after all, different angles of the wales. I suspect that they also applied manual retouching even later, already at the stage of assembly itself.
Similarly, you are already past the stage of defining the run of the external stringers. Having said that, it is probably worth saying that diagonals work very well in most such cases. However, due to the typical nature of ship hulls, usually not a single diagonal running from bow to stern, but two diagonals joining together at the midship frame, and set at different angles on the body plan. Sometimes light arcs instead of straight lines (in longitudinal projection) work even better, as you did. A typical effective trick is to set these diagonals more or less perpendicular to the surface of the hull (all the time in longitudinal projection), as much as possible.
Dear Kevin the Landlubber, and Waldemar,
The solution proposed is pretty well what I ended up doing but completely inside the software. It was very tedious and involved many iterations with a number of the software's features, before finally settling on what is, essentially, a manual solution.
In a nutshell, I sent the "cut" along a diagonal, as you noted above, but the twisting feature cannot be controlled "along" the surface of the hull. I cannot, for example, "twist" a tiny bit at the stern and then a lot at the forward three or four bulkheads. The software gives me an even twist from stern to bow.
This, of course, is not how a hull works. Planks run fairly flat in the stern area of a boat and then twist considerably as we approach the flare of the bow.
The first order of business was to figure out those diagonals. And, there again, there was plenty of mathematical fiddling until the only solution was to manually adjust the diagonals, one by one, until they looked right. This is pretty well what would happen in real life. You lay the plank against the boat and draw a line with a pencil. You then create the notches.
Once the diagonals were laid out, we get to the second problem, which you also allude to, and that is figuring out how to set the notches precisely perpendicular to the hull shape at each bulkhead. As I noted in a previous post, the software sends a cut right along the diagonal in question, but we cut 2-dimensional parts with the laser. And, also, the twist that the software gives is even from stern to bow, meaning the notches would never be quite right.
So, I created a shape for the notch and then manually placed it in the correct position, perpendicular to the hull, at each bulkhead. It was quite tedious, but I think the result was worth it.
Now, I am looking for modellers who would like to try out this revolutionary model!
Cheers,
Rick
Sorry for the delay. I was working on a 1:24 scale Lionheart. But, here I am back again continuing the Charles Mower design. Here I have inserted the dashboard. I have to say, there are dozens of designs to work from, and what I think was correct for the Charles Mower, was a simple two-dial job that sat well under the dash. I have opted to make something a little more snazzy.
I did a bit more work on the Charles Mower design. I have now created all the fixtures I want to include in the kit as 3D-printed parts. The lights are created as two-part assemblies, so the builder can include a lighting kit. The steering wheel is made as a two-part assembly so one can insert a threaded rod and use it as part of the steering mechanism.
The builder will have to add their own motor and steering gear but I do have planking available for the hull and the deck. This means I am slowly getting to the point where my kits include a lot more parts than they used to! I am excited about this project.
I am now ready to cut the parts, and I have two orders for this kit on the books.
Anyone else?
I figured out a solution for the cutwater and I think it can work. It will be an optional part. If you decide you want to give it a go, there will be a laser-engraved line on the forward edge of the keel, to show you what you would have to cut off to get the piece to fit.
The kit is now ready to go and will include the following:
- frames with notches for the internal stringers. These are made in 1/8" birch plywood
- a deck with a correct opening for the cockpit. This is made in 1/16" plywood so it can bend easily over the deck shape
- the T-rail structure so the hull can be planked up-side down. All my designs have these T-rail structures. They make the hull solid and really hold it straight during the planking process
- the cradle you see in the picture below. This will be used once you take the model off the T-rail in order to work on the deck
- the following 3D-printed parts:
- vent
- cleats, large and small
- flag stanchions
- light fixtures
- steering wheel
- cutwater. I may give two different cutwaters with the model since I am not sure how this will work. It will be a "work in progress" and modellers can help me decide whether it's worth it to create such a part, as a 3D-print.
What you do not get in the model:
- planking. I do have some heavy planking that clients use for my very large R/C models but I think it would be too thick for this model. However, I do have some 1/8" x 1/8" x 48" planking, in basswood, that might work well for the deck.
- drive gear and electronics, but you did say you wanted to make this a static model. You will still need some sort of propeller and shaft support, to make it look complete.
- little glass inserts for the lights. You will have to make those from clear styrene, or something like that.
I will be posting this model to my website in the next few days, but I am ready to take orders now, if anyone is interested.
Hurray, this model is now under construction, and I have sold several kits already. The framing kit is laser cut, and I am now working on a timbering package for the model. The 3D-printed parts package should follow shortly, as well as a decal sheet for the dashboard dials. Here are a couple of pictures of the model under construction. The first builder was quite pleased, saying it was his favorite Modeller's Workshop build so far. In particular, he mentioned the internal stringers went in very smoothly.
Here are a couple of pictures of the build so far. Note the cutwater is a 3D-printed part. She is double-planked with 5/32" x 1/2" planking.
That's a lovely looking boat, Rick, and a nice bit of development. I've had an itch to build a motor launch similar to this after a trip to Venice, Italy, last year, seeing the many beautiful launches there, mostly used as high-end taxis. In my case I'd probably take a similar approach to you and finally do something useful with my under-used laser.
I started doing these kits as a way to improve my skills with SolidWorks in about 2012. Since I have been racing sailing yachts for about fifty years, people say I have a good eye for creating boat shapes.
This has now turned into a full-time business and some of my models are now under construction in at least five countries at any one time. It's great fun and, if I can stay awake, I can communicate with builders somewhere on the planet 24 hours a day.
