Bite me
Peterborough Ontario Canada
A few years ago I was at a friends house sitting in a comfortable chair. Without warning the right rear leg collapsed. (No I’m not a heavy weight). Investigation revealed a rather large number of termites. They had chewed through the entire leg of the chair.
Which brings me to my question:
What if anything do you put on your time invested models to not have an invasion of these little monsters?
I hope the chair already had the bugs when it came into the house rather than they spread from the house to the chair. Scary thought.
Glass or plexiglass case. There should be some tiny holes for air even if in the base, but these can be filled with steel wool and no bugs can get in.
We also have house pest and termite control and inspection every four months so we are sure the house will not be eaten. :)
Are you sure it was termites? Might it have been woodworm or beetles, etc.? Generally, termites are a rather extensive problem that would go beyond a chair leg and (God forbid!) they'd have to go through a lot of other wood to get there. There are two types: ground-based and air-based. The air-based "dry wood" termites wouldn't probably go for a chair leg if they got inside a house. The "wet wood" termites travel through mud tubes from the ground up into wood timbers and you'd see the mud tubes going up into the chair leg. A break in the tubes when the chair was moved would deter them. You might want to have a compentent exterminator check it out. Most will do an inspection for next to nothing in the hopes of securing the job. Worst case scenario, you'll have to move out for a few days while they tent the house and gas it for dry wood termites or destroy the wet wood termite infestation and treat the soil to kill them off. They don't go away, so until the exterminator gets to whatever is eating your wood... "munch, munch, munch." It only gets worse with time.
I am happy in central Europe we do not have such hungry insects
Not yet at least. Termites are widespread in the S of France and moving steadily North, The UK had a (confined) termite problem in the SW that resisted eradication for almost 30 years. Like the Asian Hornet, the Tiger Mosquito, Crazy Ant and more they are coming by land sea and air.
you are right - the temperatures are getting higher and with this also the insects wandering to the north
This is a little off-topic but the best way to eradicate ants is to use a couple of spoonfulls of borax straight from the packet sprinkled around their nest. It isn't immediate but it disrupts the formation of the hard chitin shell on new ants so the colony dies out over a couple of weeks. It is harmless to plants and only harmful to animals if swallowed in large amounts- though it is acidic and should be kept off the skin. I rate it better than any of the persistent synthetic insecticides for this.
We went through this when we were living in California. The swarm got four of our houses as they came down so we got a good deal to have all four tented at the same time. The termite folks asked who was going to watch the houses the night of the great tenting event. We all looked at him like he was crazy, why would anyone break into a house full of poisonous gas. Turns out this was common as thieves would wear protective clothing and breathing apparatus and know that they would not be disturbed by the pesky homeowners. I lost the draw so pulled the watch that night. I snoozed in my car in the driveway and lo and behold a van pulled up to the house next door in the middle of the night. It scared me as I was not going to confront them and cell phones did not exist at that time so could not call the police. I just kept honking the car horn. The guys that had already gotten out of the van panicked, got back in the van, and took off. True story.
There is a company in France who use termites from another colony to kill infestations. They put spots of poison lacquer on the back of a few hundred rogue ants and let them loose in the house. The other termites fight them and eat the bodies- sharing the kills with the Queen. Very neat and clever, using ants to fight ants, and no indiscriminate spraying of toxins.
it is most likely a beetle and not a termite
How to Get Rid of Powderpost Beetles
Powderpost Beetles Leave Holes in Wood. Here’s What You Can Do to Control Them.
The presence of powderpost beetles is often first revealed by small, unexpected piles of powder near wood surfaces or materials and/or small holes (called exit holes) in the wood. If you are noticing piles of fine powder, this could definitely be cause for concern. Powderpost beetles are often brought into homes inside some sort of wood material, including building materials, wood furniture, or firewood.
The name "powderpost beetle" comes from the powder (aka frass) these insects leave behind—this actually their larvae that cause the most damage. These larvae, also known as woodworms, voraciously eat through the wood from the inside, creating tunnels (or galleries) inside the wood. As adults, they chew out of the wood and emerge through small round exit holes.
Here you’ll learn how to identify powderpost beetles and get rid of them.
Beetle Terminology: Frass and Exit Holes
Frass is the powdery mix of wood debris and droppings that wood-destroying insects leave behind as they eat the starches in wood. Powderpost beetles create frass, but so do other pests, including termites.
Exit holes are the holes that adult powderpost beetles create when they chew their way out of wood. These holes are not very large. Imagine pounding a small nail into a piece of wood and then removing it: The hole that is left behind would look very similar to a powderpost beetle exit hole.
What Do Powderpost Beetles Look Like?
The name powderpost beetle is used for a wide variety of wood-boring beetles, including true powderpost beetles (Lyctinae), false powderpost beetles (Bostrichidae), and deathwatch beetles (Anobiidae). While there are a number of similarities and differences between types of powderpost beetles, all of them invade and damage wood items, which can include different plants and items including trees, structural wood, bamboo furniture, and decorative wooden items.
These adult beetles are small (1/16 to 1/4 inch) and vary in coloring in shades of brown and red.
Types of Powderpost Beetles
True powderpost beetles, false powderpost beetles, and deathwatch beetles are all wood-boring beetles, and they all look relatively similar to one another. You may be able to tell precisely what kind of beetle infestation you have by looking at the beetles' backs.
True Powderpost Beetles (Lyctinae)
True powderpost beetles can have a more elongated appearance. If you look down on their back from above, you can see their head and eyes.
False Powderpost Beetles (Bostrichidae)
Most adult false powderpost beetles are small and range in size from 1/8 to 1/4 inch, but some species found in the wild can be up to two inches long. Their coloring is dark, ranging from brown to black, and some have reddish body parts, such as antennae, legs, and mouthparts. False powderpost beetles have a hump-backed appearance. If you look down on their backs from above, you cannot see their head and eyes easily.
Deathwatch Beetles (Anobiidae)
Though their name is a little strange, these beetles are actually related to various stored-pantry pests, including the cigarette beetle and the drugstore beetle. Deathwatch beetles typically range in size from 1/8 to 1/4 inch and are reddish to dark brown. Like false powderpost beetles, they have a hump-backed appearance and when you look down on their backs from above, you cannot see their head and eyes easily.
What Causes Powderpost Beetles?
While the cause of powderpost beetles really depends on what type of powderpost beetle you're dealing with, the short answer is that the beetles wanted to lay their eggs in the pores of something wooden. Powderpost beetles come from wood (or bamboo) materials that haven't been properly treated or protected against potential infestation. They are commonly brought into homes via building materials, wood furniture, or firewood.
Signs of Powderpost Beetles
Powderpost beetles either start as eggs inside the pores of wood or burrow into the wood to lay eggs. This can make early detection incredibly difficult, as you can't actually see inside the wood where the activity is taking place. Some of the first clues of a powderpost beetle infestation are small and unexpected piles of frass piling up around wood items, as well as exit holes in the wood.
The signs of powderpost beetle activity and the type of wood they attack vary, depending on the type of beetle.
Female true powderpost beetles emerge and lay their eggs on untreated wood surfaces or cracks. They deposit their eggs in the pores of wood where they will be protected.
Attack hardwoods, including hickory, ash, oak, walnut, and mahogany.
Most commonly found in door and window framing, plywood, furniture, flooring, as well as bamboo (although bamboo is actually a grass, it has large pores that are ideal for adult female beetles to lay their eggs).
Produce an extra fine, smooth frass.
Exit holes tend to be all the same size.
Adult female false powderpost beetle behavior differs from that of other powderpost beetles. They burrow into the wood instead of laying eggs on the surface or looking for cracks. After creating tunnels (also called egg galleries), they will find a pore or crack inside the wood to deposit their eggs into. Due to this behavior, they will also burrow into other materials if it means laying their eggs in a safe place. This is how they have earned alternative names such as the leadcable borer or cask borer.
Infestat both hardwoods and soft woods, though they are more commonly found in hardwoods. Some species of Bostrichidae beetles come from imported tropical woods such as bamboo, certain types of mahogany, and some firewood. Some species are also found in dying walnut and oak tree branches and ornamental hardwood trees, such as eucalyptus.
Capable of burrowing into wood and non-wood materials that include plaster, soft metals such as lead and silver, metal-coated electrical/telephone cables, and wine-soaked oak barrels and corks.
Produce the grittiest and most coarse frass of the three groups of powderpost beetles, with the texture feeling similar to soap flakes.
Frass is visible in the exit hole but difficult to dislodge due to its texture.
Exit holes are all about the same size.
Deathwatch Beetles
These beetles lay their eggs in the pores on the surface of wood or in exposed, cracked wood as opposed to burrowing into the wood first.
Primarily infest softwoods, their favorite being Douglas fir, which is often used in support beams (ceiling, foundation, etc.) and furniture.
Prefer old or decaying wood as it's moist wood and beetles are found more commonly in damp environments.
Frass consists of very small pellets that are more coarse than true powderpost beetle frass, but not as coarse as frass from false powderpost beetles.
Exit holes can be of various sizes, unlike the other two powderpost beetle families.
Tests to Identify the Signs
If you cannot tell what type of beetle you have based on looking at them, try the ballpoint pen test or the frass test:
The Exit Hole Test: Insert the tip of a ballpoint pen into the exit holes you see. Compare the holes to the descriptions below to try to determine what type of creature may be making them.
True Powderpost Beetle: The holes are all about the same size and the exit hole is small, so only the very tip of the pen fits.
False Powderpost Beetle: The exit holes are all about the same size and the entire point of the pen fits into the exit hole.
Deathwatch Beetle: The holes vary in size and fit both the tip of the pen as well as the angled part of the top of the pen.
Drywood Termite: Some of the holes are filled with mud, which can camouflage them and make them difficult to see at all.
The Frass Test: Examine the frass closely, using a pen tip or other tool if necessary to dislodge some from the exit holes. Compare the appearance, texture, and consistency of the frass to the below to try to determine what might be causing the holes.
True Powderpost Beetle: Smooth and fine frass, similar to the texture of flour
False Powderpost Beetle: Frass is incredibly gritty and difficult to dislodge from exit hole
Deathwatch Beetle: Gritty, coarse frass that feels like soap flakes
Drywood Termite: Large, granular pellets with ridges on the sides, similar in texture to ground pepper
Warning
You may want to wear a mask or respirator and gloves if you are coming into contact with frass. While frass is generally harmless to humans, there have been cases where people have had allergic reactions after handling it, including respiratory and skin irritations.
Beetle-damaged wood
2 Ways to Get Rid of Powderpost Beetles
Spotting holes in the wood inside your home or on your furniture doesn't necessarily mean that you have powderpost beetles, though, and it doesn't mean that you have an active infestation, especially if the holes you are seeing are in wood that is sealed, varnished, or stained. It could be powderpost beetles, and it could be an active issue, but it could also be old and inactive. The first and most important step in dealing with a wood-destroying pest is determining what pest is responsible for the damage or activity you're noticing. This will help determine what treatment is required.
If you suspect there could be powderpost beetles in your home, it is important to address these concerns quickly. More often than not, the activity you're seeing is nothing to worry about, but on the off-chance that you're dealing with wood-boring beetles, the issue will be less severe the faster you address it.
Remove Infested Wood
If you are certain you have an active wood-boring beetle issue, it is always ideal to remove, destroy, and replace any infested wood, especially when structural wood is involved. Always check wood around the infested wood for holes, as well. Infested wood can be burned or taken to a dump. When replacing the wood, don't forget to inspect building materials (and any free firewood) before bringing it indoors.
Try a Temperature Treatment
Both hot and cold temperatures will kill off powderpost beetles. Wooden items that are small and do not have any fabric, felt, or fur attached can be heated for six hours in an oven at 120°F to 135°F. Items can also be frozen in a deep freezer for a minimum of three days at 0°F. If the item is more than two inches thick, it could take longer than three days to adequately freeze treat wood-boring beetles.1
Powderpost Beetles. University of Kentucky College of Agriculture, Food and Environment.
How to Prevent Powderpost Beetles
Prevention is the best strategy for keeping powderpost beetles away, as wood-boring beetles are difficult to detect and challenging to manage once an active infestation is established. Sanitation is key in preventing a powderpost beetle issue.
When purchasing lumber or other goods made of wood, make sure is kiln-dried (this only kills off active pests and does not prevent re-infestation).
Remove destroy dead trees and tree limbs from your yard, especially near stored wood products and wood piles.
Remove infested wood from your home, garage, barns, etc.
Use special pest-control lighting around wood storage areas.
Tip
If you can, seal the wood in your home with varnish or paint. This seals the pores and cracks where beetles could lay eggs and can protect your home from powderpost beetles and other wood-destroying organisms.
In severe cases or when removal and heat treatment are not possible, chemical treatment such as fumigation of infested furniture will likely be necessary. Be sure to shop around and find an Integrated Pest Management Specialist if you need professional pest help. There are very effective and safe professional quality products containing sodium borate that will kill wood-boring beetles and protect wood in your home from a variety of wood-destroying pests for years to come.
While on the topic of insect pests a scientist friend in Georgia evolved his own method of killing fire ants. He hammered a piece of rebar into a shallow scraped pit in the ground and ran a live wire from his house supply to the top of it. The local fire ants - which have a strange love of transformers and junction boxes cluster around it in large numbers- then he used a cup-full of gasoline to set them alight. Fight fire with fire as it were. It is now his preferred method of pest control.
That's good information. My workshop building here in CA has some drywood termite activity in it and is due for a tenting and gassing. Fortunately, I have a clear elevated field of fire from the house to the workshop and three dogs to raise hell if anybody they don't know comes within 100 yards of our place. I won't have to sit in the car! :D
As a restorer of mostly 17th, 18th and 19th c. furniture, this was not an uncommon problem found in French provincial and English period pieces from damp climbs where the wood was invaded through the surfaces that were in contact with damp stone, earthen or wood floors. Often the damage was quite extensive the interior of the timbers, reduced to the consistency and tensile strength of foam plastic covered by a veneer's thickness of deceptively sound wood. There was no repairing it or successful way of consolidating it to recover its' useful hardness. It could be stabilized with the injection of hardening resins and plastic micro bubbles. The invasion was of the "wet wood" type described above. Often the furniture somehow managed to survive intact over many decades, even after the larvae had long since perished. The damage was always exacerbated by the presence of "dry rot", a cellulose consuming fungus.
The chair in question, and/or its' problem could have been quite old, having just passed critical mass. Checking beneath other wooden furniture and objects in the home for little tell-tale conical piles of wood dust is a good idea to see if there is, indeed, a problem in the home. This was not uncommon in South Florida, where I went to school in the mid 1960s.
This comment remembered me the TV series "Breaking Bad". They cover the houses with a tent, to disinfect them, under lies of infestation, to assembled a drug lab for 3 days.
So just be careful what company you hire.... HAHAHA
