YQ Bluenose Ted R [COMPLETED]
On the foresprit spar detail does it indicates150mm of the yellow line C234 is seized below the block?
Does the length listed allow for extra length for manipulation during installation?
Best regards
Where I had brass, I painted it in steel. I also bought aluminum wire for all the block stropping.
Thanks, I stropped the blocks on the cross trees with wire but it was braided. Will look to see if I have some solid aluminum wire around. What gauge wire worked for the stropping. I'm using the 3.5 mm blocks from Drydock Models.
Thanks for the help.
Ted
Here's my attempt at making part D186 at the top of the lower foremast. I think I'll use it. I had already drilled the holes for the previous part without the loop in the middle. So the actual length can't be set until the crosstree is assembled.
Happy modeling
Ted
Special to read this
When I started experimenting with blocks I also tried iron binding wire to bind the block
After turning it with a needle I made an eye
But I got stuck after I cut the eyes to size to find a way to attach it in such a way that it would stick well to the mast
But this may have to do with my way of thinking ...
I decided not to do it this way
I think it is special that you attached everything in this way
Regards
Henk
Good job Ted
I really appreciate your perseverance, I know from my own experience that sometimes two steps back and one step forward
Thank you Hank. Recently I have become less anxious about my modeling. I am trying just as hard to get everything as close to perfect as I can but am more relaxed.
Best regards
Ted
Regards
Henk
Thank you. Got the technique from Dean.
It seems Dean, Peter and RDN have become my mentors on this project.
Best regards
Ted
I'm so embarrassed I blushed Your assistance, Daniel, is at the top of the list. I wouldn't put my name on a plaque for this model without listing yours too. I didn't used to have these moments of confusion.
If you look at my notepads l, every listing is from your build and then I wrote Dean.
Please forgive my rudeness.
Btw I'm improving at your stropping technique.
Best regards
Best regards
Ted View attachment 478081View attachment 478082
Not to worry Ted, you actually did pick the top 3 BN builders as far as I'm concerned. I would not have had near the success were it not for these 3 individuals.
To me your metal stropping needs some improvement, it just takes practice. I spent several days with this before coming up with what I called acceptable appearance. Starting with this.
and ended up using the one on the top right. For me the key was holding the tiny sheeve study (hands free) so I could concentrate on the twist and finish trim.
Thank you
I see what you did with the wire. I got some PE hooks from Drydock but am now confused how to use them.
Do all of the C171 bolts get a hook?
Which detail do I use?
Ted, all of us whom you follow show how we did this in detail within our build logs. I encourage you to do your own research. Once you have done that and still cannot find the result you're looking for, then ask for help. I went back through my build log (researched) and found this post.
I fully agree with Dan's last post; there's an awful lot of build information in the various blogs, also with regard to block stropping.
Pick the method best fitting your capabilities (make some test pieces) and stick to it for the duration of your build. Before applying either hooks or eyes or rings, make sure you understand the function of the ropes or spars you're working on before attaching anything permanently; if you haven't done so so far, make yourself intimately familiar with every detail, study the drawings, even if you think you've seen it all and re-read build logs you've read before. If necessary, make your own sketches to make the subject your own.
