You can feel the smooth-baby-bottom-surface of your accurate woodwork, Dean. But I assure you that we can see that on you pictures.I have to cover up to the next bulkhead and stop there. The reason being, the very end or tip, is the intersection of the horizontal stabilizer and the tail. A busy intersection that will require some fit adjustments. Only then will it be safe to cover that area. It will be more obvious when I get to that step.
As good as it feels to be near completion on the engine nacelle, I have to do it again on the other one! Yikes!
Then I can finally start work on the horizontal stabilizer and the two tails, which all have flaps.
At that point I can fit and glue everything together and finally cover the end of these engine nacelles.
Then a lot of tedious work will begin after putting a few coats of paint and sanding. That will fill in any wood grain and give me a very smooth surface to work with. Then I can start to get into all of the details and application of panels. So much work ahead and I just keep chipping away. We all know how that goes. Keep your sights on immediate goals and don’t get overwhelmed thinking about the full scope of work ahead!
Note - due to the inconsistencies of the wood color, grain, etc. and multiple panels, it gives the illusion in photos of being unlevel in some areas, but I assure you it’s sanded flush at all joints and as smooth as a babies bottom.Once painted it will be more obvious.
Ok…back to work…
And about all the time consuming next steps ……… what is the satisfaction of building a model in a few weeks/months, then the next etc etc. I only know that building a model is a multi-years project.
You know also that a solid and smooth foundation is the basis for the best outcome.
Just like you always looked forward to some far-ways steps in the build of my models: looking forward to the panels and the paintwork.
