cleaning solution
I just finished deck and the bulwarks in and outside came beautiful got glue between planks, I notice some models install planks first some don't, anyhow it's done, I found out paint thinner is a good way to cleans up dry glue anybody knows I better way ,,PS not off paint thinners work the same if anyone interested i have the make super glow retarder thinner it work real good but it very strong thinners, again if anyone knows better please let me know ,,,thanks
If you are talking about CA glue, is there a reason you are not using acetone?
I also found the following with a quick search.
To remove super glue from wood, use acetone (found in most nail polish removers) to soften the glue, then gently scrape it off with a plastic scraper or dull knife; be sure to test the acetone on an inconspicuous area of the wood first as it can damage the finish on some types of wood.
Key points:
  • Acetone is the best option: Acetone is the most effective solvent for breaking down super glue.
  • Apply with a cotton ball: Soak a cotton ball in acetone and dab it onto the glue.
  • Scrape gently: After the glue softens, use a plastic scraper or a dull knife to carefully remove the glue.
  • Test on an inconspicuous area: Before applying acetone to a large area, test it on a small, hidden part of the wood to ensure it doesn't damage the finish.
Alternative methods if acetone is not suitable:
  • White vinegar:
    Apply white vinegar with a cloth and let it sit for a few minutes before gently scraping.
  • Vegetable oil:
    For delicate woods, try applying a small amount of vegetable oil to the glue and then scraping it off.
  • Fine-grit sandpaper:
    If some glue residue remains after using a solvent, lightly sand the area with fine-grit sandpaper.
The glue has probably soaked into the grain of the wood, so solvents and scraping probably won’t be good enough to clean things up if you plan to stain or leave a natural finish. If you plan to paint, then maybe don’t mess with solvents; just sand abd scrape to get a smooth finish
Key points:
  • White vinegar:
  • Vegetable oil:
thanks, acetone will work, ty,
I think a key point is making sure there are no open seams between pieces. If there are gaps filled with glue, better to take them off and redo them to get a proper fit.
yes, I tried that I try to close the gaps, best I can second, I fill in with white glue its works, but closing the gaps better its hard sometimes I think I didn't, but too much glue then comes apart,
Actually there should be no glue between planks or other similar parts as they sit tight against each other. The planks, for example, are glued to the frame or bulkhead not to each other. Too much glue is as much trouble as not enough glue. If you study some planking tutorials you will see it is not difficult to form your planks so they always sit tight against each other.
when you glue just the deck sometimes their peel of the plank's strips sometimes, I guess a lot of clean up after!
