Certainly. But don't spend any money. Just make your own using spare strips of wood you have sitting around. I attach sandpaper using double sided tape. I must have ten different sizes. I use 150 grit for bulk removal - 240 to clean stuff up - and 320 for fine finishing.would you use sanding blocks instead of the belt sander
How do you know how much to edge bend without a forming set up? I usually start with a piece of paper and shape it as if I was going to spile the plank, but then use the paper form and cut out a wooden former to suit as in the photo below so I know it will be the right amount. Once it is shaped I can then hold it in place with finger pressure for a minute or less until the PVA sets enough to hold it. No need for clamps. Since the photo below was taken, I have gone to a hot air gun. It is easier to control and works more quickly. Heat aand.or time works. More heat, less time. I have read numerous times that it is heat that is key and whatever the chemistry in softening wood, I don't really care, I just find it much easier to do the initial edge bend set up if the piece has been thoroughly saturated with water. Heat for a few minutes or at room temperature overnight work the same in my experience.I have edged-bent with the plank bender
Contrary to common perception, there is no length of time you should soak ship modeling wood prior to bending, so, therefore, the temperature of the water is irrelevant.On a different note how long should you soak the wood prior to bending and should it be cold , luke warm or hot ish water ?
BobLet's not forget also that plank must be spiled (shaped) accurately before bending. Edge-setting (bending across the wide dimension of the plank) should be avoided except in very small amounts.
I know. Particularly on slab-sided period ships, there will be runs of planking with a very slight curve where plank can be edge-set to fit just perfectly and spiling avoided for a large area. This is why I wrote that "edge setting should be avoided except in very small amounts." I figured most would recognize that a little bit of bend will be okay on a lot of hulls, but I didn't want to give the impression that the shape of a plank can be bent in the same way that the curve of a plank can be bent because trying to do both at the same time is where most modelers seem to hit a reef, if forum posts are any indication.Bob
I used to be of that school, but changed after trying edge bending as shown in the photo above. Saves wood, is easier, and it works. There is a limit to the amount of bend depending on the thickness and width but getting to the same curvature that would be achieved with spiling hull planking has not been a problem. In the end, I have found that both methods work equally for hull planking and similar tasks.
Close grained species such as holly, pear, castello and boxwood all work with this method. I am not sure the South African mahogany (sapele) or walnut seen in many kits would work as it is so open grained. '"fine hardwood" coarse-grained walnut planking strips.
