tool problems
CONWAY SPRINGS, KS
OK GUYS NERED SOME HELP VERY VERY BADLY ALSO BAD, BAD WEEK OH SHIT I HAVE THE ULTIMATIUM SLICER COUL ANY ONE TELL ME MAX CUTBLADE WAS IN THE MACHINE WHEN DELIVERD I AMM HAING LOADWS OF PROB CUTTING 1/16 MATERIAL NEXT WHAT IS THE BEST NIPPER TO CUT THIN BARASWS ABOUT THE SIZE OF PAPRT CLP ALL HELP WOULD BE GREATLY APPRECIATED. GOD BLESS STAY SAFE ALL DON
Hi Don.
I can't help with your slicer problem, but among the best cutting pliers at affordable prices are those made by Xuron in the USA.
Hi Don,
I have that slicer but I'm not sure I understand what you are asking about. If it is the maximum material thickness then you should not be having any problems cutting 1/16" stock. I cut that thickness in pear and boxwood all the time. Or were you asking about getting replacement blades? Mine came with 5 spares. Just be careful replacing it - the blades are crazy sharp.
Or if you were asking another question please try again and I'll watch this space. YBIC, Paul.
HI PAUL THANK YOU FOR REPLY SHOULD GIVE IT MORE TIMME AND I DO APOLIGIZE FOR THE CAPS,SPELLING, COMPOSISTION ETC. NO COMPLAINTS THROUGH MY FAITH IN JESUES CHRIST MY LORD AND SAVIOUR I DO THE BEST I CAN WOULD LOVE TO GET ANSWERS IN CAPS I CAN PUT THE MAGNYFIER AWAY... NOW FOR IMPORTANT STUFF I AGREE WITHY YOU OBOUT THE SLICER I CAN NOT CUT THROUGH 1/16/ MATERIAL AT ALL DO NOT KNOW WHY MAYBE THE PRE EXISTING BLADE O THE OTHER PART OF QUESION IS I NEED TO CUT SOME BRASS WIRE QUITE A BIT THE THICKNESS IS APPROX THE SIZE OF A MEDIUM PAPER CLIP HAVE A ZURON BUT NOT DOING IT..L AGAIN FORGIVE ANY INCONVINCE THAT I HAVE GIVEN. TGOD BLESS STAY SAFE YOU AND YOURS DON
HI DON, I HAVE NO PROBLEM AT ALL WITH ALL CAPS. MY DAD DID THE SAME THING WHEN HE WAS YOUR EXACT AGE. WHEN CUTTING THICKER MATERIALS WITH THE SLICER IT HELPS TO 'SNEAK UP' ON THE CUT. WHAT I MEAN IS WHEN CUTTING LARGER MATERIALS THEY TEND TO BREAK OUT THE BOTTOM OF THE CUT RATHER THAN BEING SMOOTH. THE SOLUTION IS TO CUT ABOUT 1/16" FROM THE CUT LINE FOR THE FIRST CUT AND THEN WHITTLE AWAY WITH THE SLICER UNTIL YOU REACH THE FINAL LOCATION.
I'M SORRY I DON'T HAVE ANY SUGGESTIONS FOR CUTTING BRASS WIRE. I ALSO USE THE XURON SIDE CUTTER AND IT HAS BEEN FINE FOR ME. MAYBE YOU MIGHT LIKE TO TRY COPPER WIRE - IT IS SOFTER THAN BRASS.
BLESSINGS
I HAVE THE SLICER AND HAVE NO PROBLEM WITH 1/16 WOOD STRIPS.
ARE YOU TRYING TO CUT WIDE PIECES OF WOOD? THE SLICER MIGHT NOT BE ABLE TO CUT WOOD MORE THAN AN INCH WIDE. OF COURSE THAT DEPENDS ON THE TYPE OF WOOD AND HOW HARD IT IS.
I ASSUME YOU ARE NOT USING THE SLICER ON BRASS? THAT MIGHT BE DANGEROUS AND PROBABLY WONT WORK.
I CUT BRASS WIRE WITH A CHEAP STANDARD PAIR OF PLIERS FROM THE HARDWARE STORE.
HELLO DON
LATE TO REPLYING, BUT I SUPPOSE YOU HAVE CHECKED THAT THERE IS A BLADE IN THE SLICER? EVEN A.
BLUNT BLADE WOULD WORK TO SOME EXTENT.
BRASS WIRE? JUST SIDECUTTERS, FOLLOWED BY A FINE FILE TO RESTORE A SQUARE END AND TRIM TO
EXACT LENGTH.
HI DON,
I WILL ALSO WRITE IN CAPITALS TO ASSIST YOU. I HAVE TAKEN A PHOTO OF THE NOTE THAT CAME WITH MY SLICER AND THE SPARE BLADES I PURCHASED.
I CUT 1/16” MATERIAL WITHOUT PROBLEMS. I NIBBLE AT IT RATHER THAN CUTTING IN ONE GO AND USE A SHARP BLADE.
I HOPE THIS IS WHAT YOU ARE LOOKING FOR.
BOY OH BOY GETTING THE MUCH NEEDED ANSWERS I AM GOING TO REPLCE TH BLADE THAT CAME WITH IT AND SEEWHAT HAPPENS. THANK YOU ALL THIS IS WHAT FORUM SHOULD DO0. HOPE I CAN DO THE SAME FOR SOMEBODY. GOD BLESS STAY SAFE YOU AND YOURS DON
HI DAVE AS YOU KNOW COMPUTER ILLERTERATE HERE HOW DO I DO THAT AND WHILE I HAVE YOU I HAVE BEEN TRYING TO JOIN THE GROUP IN OHIO SENT EMAIL A COUPLE OF TIMES UNDELIVERAQBLE. GOD BLESS STAY SAFE YOU AND EV DON
"BAD WEEK OH SHIT".... I'VE HAD LOTS OF THOSE. KEEP ON KEEPING ON. BLESSINGS YOUR WAY.
HELLO DON, DO YOU USE WINDOWS?
YOU CAN ACTIVATE THE MAGNIFIER WITH THE KEY COMBINATION WINDOWS LOGO KEY + THE SIGN (+).
TO DEACTIVATE THE MAGNIFIER PRESS THE WINDOWS LOGO KEY + ESC
IF YOU PREFER, YOU CAN ZOOM WITH THE MOUSE, PRESS CTRL + ALT + MOUSE WHEEL UP OR DOWN
GREETINGS
