**VIEW THREAD HERE** |
... with 1200 grit sandpaper, you will sand for hours, if not days. Technically speaking, 1200 grit is very fine sandpaper, used mainly for finishing surfaces. However, there are no golden rules as to what grit to use.best number to sand down planking I was told 1200 what you pros thinks about it, thank you,
sorry I forgot to tell you the second layer my mistake sorry, but I see the proceeded of all grids its very well instructed, thank you for this... with 1200 grit sandpaper, you will sand for hours, if not days. Technically speaking, 1200 grit is very fine sandpaper, used mainly for finishing surfaces. However, there are no golden rules as to what grit to use.
How much material you will need to remove? If it is first-layer planking and you need to build a base for second planking, 120 ~ 140 should suffice. Again, we don't know the original state of your hull and how much material you may need to remove. Sometimes 80 grit should be just about right to start. Also, what grit sandpaper to use depends on the plank material. The harder the wood the smaller the size of grit sandpaper you will use.
Once the initial sanding is done, you may use 240 ~ 360 to make the surface smooth, and then 600 and so on. The last thing to prepare for oil or paint is to use scrapes. Scrapes will remove all sandpaper traces.
There is no 'best' when using abrasives.best number to sand down planking I was told 1200 what you pros thinks about it, thank you,
A couple of natural materials are abrasive enough to sand wood and polish metals, etc. Some Ancient Egyptian murals depict woodworkers, sanding furniture with sandstone blocks (what’s in a name?) Shark - or dogfish skin was known since Roman times.Good replies here. We are spoilt for variety of sanding paper now.
Wonder what the Modelers of early last Century and before used even before Sandpaper came on the scene?
You don't have to use weed unless you wantHi Jim I live in Australia so cannot try the weed. The Aboriginals of this country are great carvers and used stones to sand down things. They also used fire to hollow out wood and then if they were making a Didjeridoo, they sometimes used hot pebbles to help smooth the internals of the hollow
This is a joke, but think of it like this… 1grit would be one big piece of gravel on a backing. 100 grit would be one hundred pieces. 2400 would have 2400 pieces of abrasive ad nausiumThis doesn't answer the question of what grit to use but might be of use when deciding on which abrasive...
mm, I use 1200 if I'm getting to fine polishing. Something like a 2 part finish is very hard, and to get a 'real' glass like polish you work through to paste compounds that are, literally, used to polish rather than cut. Imagine the kind of refinishing you might do on a car. Begin with the usual grits, using a machine of course, and cleaning down well between changes to ensure there are no stray 'large' grits to scar the next level. 600 to 1200 to 2000 and on to paste compounds and sponge buffs.120 surely, not 1200 …. Extra zero made it’s way there, somehow.
