I was given a Corel Flying Fish model from a relative. Man , to me there seems to be no real directions. Bad choice for a starter ship? bought a couple of books on ship building which were just more confusing. Supposed to be a relaxing hobby.
This is the first boat I’ve done and I’ve learned a lot.i had no idea what I was getting into.Hi I’m jay chapman from Roseville Minnesota. I’m working the cutty sark.from Artesania Latina,s.a.
Helluva learning curve, huh Jay?This is the first boat I’ve done and I’ve learned a lot.i had no idea what I was getting into.
Welcome to the forums Jay !This is the first boat I’ve done and I’ve learned a lot.i had no idea what I was getting into.
AhHa!! The last picture of your Cutty Sark shows that if you throw money at it it gets easier.
Hello and welcome to the forum, from NYHi I’m jay chapman from Roseville Minnesota. I’m working the cutty sark.from Artesania Latina,s.a.
Typical bulkhead setupYou have what’s known as a POB, Plank on Bulkhead kit. The principles of building these are the same for all such kits, simple or complicated. There is a central spine, commonly called a false keel. The bulkheads are glued crosswise each into its respective notch to provide the skeleton of the hull. You then add the planking to the hull. Some of these kits require two layers of planking. The first supports the second finished layer. Check out build logs here on the forum to get the idea. As Dave says proceed step by step. Don’t worry about future steps until you’ve completed the hull.
Roger
