which JB Weld?Greetings
Any tips on the best method for gluing brass to wood? CA doesn’t hold and I have not had success with epoxy (JB Weld).
Thanks
Dan
Agree.it might help to clean the surface of the brass with fine sand paper or steel wool before gluing.
CA is indeed very useful, but it does have a couple of limitations to keep in mind. First is that it will soak into the grain of the wood, which may be less than desirable if you plan to leave the wood unpainted. It also tends to be brittle in my experience, which limits its effectiveness when you have a small surface area in contact. When I am trying to bond anything to wood with CA I like to add a pin of some sort to increase surface area of the join. If it's a flat piece of PE, then I solder a stub on the back, or if it's something with depth I will drill it and CA the pin to that first.Ca should do the job as well. Don’t use the thin. Use medium or thick. Make sure the brass is clean and scuff it with some fine sandpaper.
You can use sand paper (60 or 80 grit) on the back of the part you are goint to glue,or use one sharp point and make some scratches on the part,clean the part with acetone and then you can use epoxy ( 5 minutes is perfect ) or CA (gel is better) I have been using this method for years and I am very happy with the results. JB weld is fine, the problem is that cure in 10 to 15 hours and it is to thick.Greetings
Thanks
Dan
JB Weld Kwik dries in 5-10 minutes.....You can use sand paper (60 or 80 grit) on the back of the part you are goint to glue,or use one sharp point and make some scratches on the part,clean the part with acetone and then you can use epoxy ( 5 minutes is perfect ) or CA (gel is better) I have been using this method for years and I am very happy with the results. JB weld is fine, the problem is that cure in 10 to 15 hours and it is to thick.
In a situation like that, I would solder pins to back of the strake to go through holes in the hull.JB Weld makes a number of products. Some have thickening filler and a few do not. I like JB’s Original Formula. This is a thickened slow curing version. I like the extra working time that it gives me. It seems to now be harder to find.
Thinking more about my brass sheer strake. Skip most of the nails! Use a few nails to position the strake. Punch additional holes into the brass, maybe 3/32 in diameter. When the strake is clamped firmly to the hull, Epoxy should squeeze out through the holes forming a mechanical lock when cured. Excess squeeze out can be easily sanded off without damaging the harder brass. As they, try on scrap first!
Roger
