I used an oil-based stain to stain some parts before gluing. The instructions encouraged staining before assembly. I emailed the PVA glue manufacturer (Gorilla) to clarify if the stain would affect the glue joints. They responded with an assurance it should be fine. The joints in question were those fixing the bulkheads/frames to the false keel. Needless to say, about five of the 14 joints came loose easily. However, there could possibly have been two other contributing factors - laser ash and lack of glue.
The joints first need to be sanded to remove the ash created when the parts were initially cut with a laser, and being stingy with the glue is false economy.
Given this is my first build, I thought it wise to make these observations known, to hopefully avoid others falling into the same traps.
However, I am not convinced gluing parts stained with an oil-based stain is completely trouble-free and will result in a full-strength bond. I used oil to avoid the wood swelling.
