Indian Ink won’t dry
  • Thread starter Thread starter EspenT
  • Watchers Watchers 8
Selbu, Norway
I was recommended to try Indian Ink to color things like the yards with Indian Ink. It contains a lot of pigment and also shellac.
My problem is that even two weeks after I brushed on a thin layer it is still not dry. If I lightly drag my finger over it it leaves a lot of color on my finger.
Does anyone have any advice?
I heard or read somewhere that shellac has tendency to never completely dry when becomes old. It can become old in a few years. In that article it was recommended to discard shellac in a year after opening the can. May be this is the problem you are having?
I just bought the bottle, but I don’t know when it was produced. I bought a liter from a pen store :) so maybe it has been standing there for years.
Did you shake up the bottle before use? It's possible it may have settled. Beyond that, I have no idea what may have caused the problem you describe. I've used a lot of India ink over the years, some of it quite old, and never had any problems with it. When it dries, i.e., when the alcohol evaporates, it shouldn't smudge. Note that this first comment is in reference to India ink, not Indian ink. Generally, the basic ingredients of India ink are shellac, alcohol, and lamp black.
You wrote Indian ink.
Indian ink
is an entirely different type of ink, also known as Chinese ink. Indian ink is water-based. Its basic ingredients are water, gum arabic (as the binder,) and black pigment (generally made from ground burned bone.) Indian ink is the stuff used for writing Chinese and Japanese characters with a writing brush. It is often sold in block form with a depression cast into the block into which water can be placed and used in much the same fashion as solid block watercolors. It's also sold as ground powder to be mixed with water and premixed in bottles. Indian ink is not waterproof and, given any moisture, will smudge when rubbed.
Is it possible you used Indian rather than India ink?
Indian ink
Aha. It also says Chinese Ink on the bottle. Thank you for clarifying this. Much appreciated.
India ink, Chinese ink or Indian ink is all the same. Just carbon and water.
Sometimes they ad shellac (contains alcohol) or gelatine to make it waterproof or more durable.
India or Indian ink is only available in liquid form and Chinese ink can also in solid form (ink sticks).
To your problem. Finish the painted wood with shellac or another finish to make it durable. Probably you use a Indian ink that only contains water.
There is also Sumi ink, same thing. Here you see the process
Thank you Steef66,
Applying extra shellac on top was the solution. The ink I purchased claims to contain shellac, but it is probably not enough to work on wood. It is a writers ink and it seems to dry fine on paper.
I will purchase a higher quality ink and see if that helps. If not I could always use your solution.
I was going to suggest this... Koh-I-Noor Dye-Based Universal Drawing Ink.
Back in the day, it's what we used with drafting pens. A few outfits made ink... Koh-i-Noor, Staedtler, Pelican, et. Pretty much any drafting type black ink should do the trick. Good density, and dries smudge-proof (based on my personal experience using it on both drafting vellum and mylar). You can still source it from Amazon as well as any shop that deals in drafting or art supplies. Also available in both small containers and well as larger bottles.
Another possibilty is to use fabric markers.I am using them since 2 years to color small areas ,parts or spots without using masking tapes.
They can also be used for drawing symbols on the sails, Rubbing and Light fastness are good.
Applying a varnish on allready marked or dyed area is also possible without changing the main color
I had the same problem, for another reason, old stain. I found a flameless heat gun made by Diafield that works fine. It also comes with a diffuser to redirect the heat. It takes just a few passes and the stain was dry.
