HMS Pandora 1779 - Modelship Dockyard Scale 1:72 by dakyzw
Very good work on the copper sheating and also the copper nails
I guess it is copper wire which you use...... what is the diameter of the drill and wire?
Based on the scale of 1:72 and the nails which are in scale it is looking like 0,3 or 0,4mm - how can you drill these 3000 holes and do not break permanently the drill bits?
是的,这是0.3的铜丝。还好了,钻头没有断,再细的就很难说了
Yes, this is 0.3 copper wire. Fortunately, the drill bit did not break. It is hard to say if it is thinner.
Which type, kind producer of the drill bits are you using?
我是在中国淘宝网点买的,有很多网店卖,0.2-5.5各种规格都有
I bought it on Taobao in China. Many online stores sell it in various sizes from 0.2 to 5.5.
添加炮门收放细节,自制羊角栓。船长室羊角栓有点儿大,进行修正。
Add gunport opening‑closing details.
make custom cleats.
The cleats in the great cabin are slightly over‑size, carry out correction.
