Another... Halcon - 1/100
Hi Kurt. What you wrote makes sense. I am wondering if this was a Baltimore Clipper. There were five British ships name Halcyon, but none named Halcon so it is not a real British mortar or bomb vessel. If this is a representation of a Baltimore Clipper, didn't some of them have a swivel ring and long gun somewhere on the centerline of the deck?
Interesting stuff.
The Chinese model of Halcon is a Baltimore Clipper, though built in Spain from what I found online.
@AllanKP69 @DARIVS ARCHITECTVS
Thank you for starting this interesting discussion!
A thought on the origin of this vessel. Searching online for the name only returns models. My build is the 1:100 cheap chinese kit. There seems to have been a 1:60 kit which some of the detailed plans originate.
I think the Halcon is supposed to be a generic American Navy Baltimore Clipper (Eagle on the transom) but not representing an actual vessel.
Also, I am almost 100% sure that the chinese kit is based on the older plans, since it matches almost exactly.
About the mysterious center gun.
I had also wondered about it. In the original (1:60) plans, some ropes are shown, to move the cannon, but there is nothing to hold the recoil. It would not have been able to be be fired like this.
Might be just missing details, but the side cannons have all details displayed.
I have also seen similar vessels with a center swivel gun/mortar.
I am now very inclined to scrap that center long gun as it is and either
  • exchange it for a proper swivel gun/ mortar similar to this:
    or
  • equipping the Halcon with 4 more of the smaller side cannons.
Convince me of one or the other!
Have great sunday!
If you want to have another gun, a small mortar would be the way to go. I wonder if the ship could handle the weight.
Chapter 16
Jack is back!
The model shipyard has opened up again after a long break.
Although there are still a few details to make/ finish for the deck equipment, I decided to start on the rig.
As always the original 10$ kit plans are very vague. So I looked at a a lot of online images of the Pride II, the Lynx and other model plans about the masts and especially the cross trees. The parts for the cross trees are from the kit and at this thickness were very fragile. So I soaked the thin sections in superglue which stabelized the wood enough to be able to drill holes near the ends.
At 1:100 the bottom parts are 4mm and the top parts 3mm tapering to 1.5mm
The top part of the 4mm lower mast got squared off to match the sources.
The 3mm top masts got a square footing by filing the bottom 1.5cm square, glueing flat pieces to the sides, filing everything down to 3mm again and then creating the small transitions.
I am rather happy about the extra effort I took even at this scale because it just looks just so much better then just leaving 'round dowels'.
Chapter 17
Another day and she has a bowsprit now!
Again no material from the kit was used here (which only came with some rather soft round sticks).
I again took references from the PoB II.
This time a started with a sqaure sectioned beech piece of 4mm which I cut on my litte Proxxon table saw.
The round bit was then lathed, the rest carved and sanded. It is 94mm long.
I had to take of some off the already assembled bits in order to fit the bowsprit properly.
Also I had to square the originally round protrusion for the bowsprit in the bulwark. I had drilled that earlier in the project thinking the bowsprit was going to be a round stick and before escalating this 10$ kit.
It then got attached with a blackened copper bracket.
The jib boom is 3mm at the thickest section and was sanded while spinneng in a power drill, each end separately.
The assembled (not glued) masts and bowsprit (jib boom will be permanently glued later).
Have a nice weekend everyone!
Chapter 18
I made progress with a lot of the detailing. The smallest progress (literally) is the ships bell in 1/100 scale.
But first, some davits
The another detail (outside the plans) which I did not find the english term for. What is the part on top of the bow rail called?
This was followed by the tiller, made from a solid piece of cherry.
Davits and tiller assembled
Next I made the levers for the capstan, turned with my Makita and sandpaper.
Capstan levers stowed away
Next part was the ships bell. I made this out of a piece of 2.5mm brass pipe which I cold spin formed and filed.
Assembled on top of the compass compartment.
And finally I made the cannon port lids (which also do not appear in the plans). I took reference from the Pride of Baltimore II and Schooner Lynx, like with many of the other details.
The front ports are closed.
Since I opted against the 18 pound center gun (from the original Halcon pIans), Iwill add a fourth 12 pound gun per side.
Next I will sort out the gun rigging, so I can easily add them once the rig is done. I am afraid that if I add them now I will destroy them in the rigging process.
One major hull detail is still missing, the golden Falcon on the transom. I think I will tackle that next.
Then it is finally time to permanently put in the lower masts and start on the stays and shrouds.
Have a great sunday everyone!
Awesome work! I`m torturing myself with this kit and lack of instruction makes it rather hard for a novice. Could you please share STLs for the addons you`ve made for it?
The Halcon was the first ship I built And I had to throw out the first model. Perservered with the second model and finished it but cetainly not to the standard which you are achieving. I feel like a total amature (which I am) next to your professional work. but I will get better
But I used the origional kit parts & I do remember that they were very cheap (in cost of kits).
I say again your work is brilliant and something the rest of us can aspire to
Thank you for your kind words! Your Build looks decent and If you are content that is all that counts.
The way my Halcon project escalated is really quite something.
I have build a few wooden model ships before but never in 1:100 Scale.
When I started this kit (which was gifted to me) I thought it would be a short fun project.
The more I progressed the more I got interested in the type of vessel and the details which lead me into doing lots of research on Baltimore Clippers.
And here we are now with pretty much everything except the hull being modified or scratch build up to a point where I am considering making my own pulley blocks...
Chapter 19
Ok, so contrary to the conclusion of my last post, the rig was not the next thing, because I felt the transom looked a bit naked.
So I decided to give the Falcon and the ornaments a go.
I do enjoy 3D CAD modelling but I felt the falcon was beyond my skill level.
So instead I carved/ scraped it out of ABS sheet plastic after some failed attempts in wood vaneer.
This photo shows the cut out, semi finished carving.
For the ornaments on the transom (which you can see on the printout on the image above) I first tried to 'paint' them with white glue on a plastic sheet so I could detach them after drying and then paint them with gold paint but it did not turn out well.
So I CAD modelled them (simple extrusions with rounded edges) and 3D printed them with a 0.2mm nozzle. That turned out well enough for me.
Here is the finished and painted carving and the 3D prints assembled. I also drilled the hawseholes and added the fittings (not included in kit or original plan)
Hand for scale
The next update is about the tiller pulley system (picture is before the upgrade)
The original plans did not show enough detail, only 'something with pulleys on either side'.
So I did a bit of research and found this amongst other examples. And this is what I went for: a closed loop system with a lock on top of the tiller.
For this I souldered a little contraption to go around the tiller and fix the pulley blocks to. By far the smallest thing I have soldered so far.
And attached it to the tiller
And the put together with wire bent hooks, 3D printed 2mm single blocks and some hemp coloured Gütermann silk yarn
And again, hand for scale
So long and have a great weekend!
Was messing with some ai generated model from a photo of a bird to make some sort of a figurehead, I swear it looks ok from meter away =D
Sweet!
I have actively ignored the galleon so far. Not sure I will make one.
Which AI App did you use for the STL creation? Meshy? There seem to be a ton of new apps. Have not checked them out lately.
Sweet!
I tried Meshy but I burned all my free tokens before realised that it won`t allow me download files generated by the latest model they have... so I used Hunyuan3D 2.0 running locally. Works fine for something as simple.
Chapter 20
Before starting rigging (for real this time, honestly) I finished the cannons.
I made a little jig to get even lengths for all of them.
Finished piece
I did not glue the guns down yet since I am pretty sure I would brake them off while handling the hull. I will do that once the basic rig is done and also give the ropes some 'gravity'. Also the gun port lids will follow towards the end.
Masts glued in using ABS sheet templates for the correct angles. Mast footers and pinboards added.
Starting with the shrouds on another jig.
For equal distances I used a wire bracket when attaching the dead eyes
First I used a thicker Gütermann silk yarn, but it looked off.
To be honest, the dead-eyes are also a little large at 3.5mm but since I wanted two different sizes (smaller ones for the backstays) but 2.5 and 3.5 were the smallest ones I could obtain, I went with it.
So I switched to a thinner silk yarn with looks a lot more scale here.
Current state (top masts are not glued in yet)
I am really happy with the way she is turning out.
