De Agostini HMS Victory Cross Section Missing Issues 139 - 150
I recently bought this ship kit (all 120 issues) and it had another 18 issues which the original buyer was not sure why the subscription kept going and just cancelled it.
I found that this was for a cross section (another 30 issues). I am now looking for Issues 139 - 150. I tried the web links but they are deleted.
Does anyone have them, or know who I could contact to find out if copies are available?
Thanks
Robert
Just a shot in the dark for you, sometimes if you google search the issue and add .PDF at the end of the search there is more often than not some form of library that people have put up over the years. I found it thru searching a particular woodworking plan and noted there were many different libraries to available, and most were free. It's worth a poke around out there anyway.
Good luck
Shaun
Hi Rob Melbourne
I am building the x section of this kit I will check tonight what is in those sections maybe you could scratch build them ?
Andy
Good luck
Shaun
Hi Shaun,
Tried that, no luck unfortunately. Even the D'Agostini site no longer accepts queries as they no longer produce the kit. I will keep searching for the issues and then see about scratch building the pieces
I have checked my copies of the X section.. the only thing that might cause you problems are the guns not easy to fabricate the barrels. Artesania make a 1/84 Victory. Maybe they could help you with barrels the rest seems to be strips and deck supports both easily sorted
The other alternative is to use the parts you have got to sort out any problems with your full build
Andy
Hi, I have the instructions in PDF, it represents 146 pages and the file is 103 MB. I can send it if necessary.
Hi Robmelbourne, i may have extras in storage, i need to check though.
Righto, i have checked, i have the parts, but no extras, the extras i do have are 108-120.
Attached photo is the parts 139-150.
There maybe a way to use these as templates to scratch build these parts.
And if your in melbourne aust, theres a bloke who runs Models and hobbies in boronia who actually did a work stint on the Victory and he may still have some of the authentic (yellow stuff) Victory paint leftover from when he built his model.
Yes, I am in Melbourne, East Bentleigh. At least you have them, that is a start. The laser cut pieces I could do from scratch, need a photo of them at actual size. I found a place here that will laser cut, will need to confirm with them what file format they require too. Then will need to confirm the dimensions of the pieces in the other packs. I can make, buy as needed. Will need to know quantities of those items too. Pity you are not in Melbourne as I would gladly drop in and do all the measurements, counting, etc. But there is certainly no hurry.
The other option is - I now have duplicates of Issues 121 - 138 if YOU are short and the associated parts.
Luckily i am in melb, endeavour hills to be precise and yeah we can organise a meet n greet to measure up.
I started collecting the Victory from 108, during the production run for Sovereign of the seas, i figured i could alway get the missing parts later, on back order, oh how wrong was I.
I had to hunt on ebay, and i managed to find a full set 1-120, downside is the magazines are in german.. but thats fine as i downloaded the
english instructions.
Thanks
Robert
I have the same issue and talking to the suppliers brought no joy at all, in fact I found them absolutely rude and not interested in supplying anything at all.
HI there,
It will take a little while but I am ready to come up and take measurements of each of these parts. I got a lots of timber spares from a guy and may have a lot of it, just need to adapt some of it. Other pieces like the cannons and belay pins i can source from a shop in Ringwood. I look forward to hearing from you. I will trace those templates so I can make my own parts there. A bit of work to do, but it will be worth it in the end. Rob 0411235175 I look forward to hearing from you
Thanks Xander, I will let you know.
Hi Xander,
I have someone who has the parts and I hope the instructions. Once I meet with him and make detailed notes of the parts so I can make them or buy from a supplier here, I will see what he has in the way of instructions and photograph them, else I will ask for that file. Rob
every now and then these come up for sale in NZ. currently the De Agostini Endevour is on Trademe here. The seller is trying to get most of what he paid for the kit. (selling for $1250.00) I picked up the victory for $400. the Sovereign of the seas also for $400 and the endevour for $250. however i dont think i have seen the Victory with the extra parts.
That's fortunate
