Good afternoon (it's about 3:00 PM here in Florida).
I am getting ready to paint a small model hull (the middle project in Model Expo's three project intro group (Norwegian Sailing Pram). I have sanded everything to provide a good base for paints and primers. I also applied two coats of sanding Sealer (Sand 'n' Seal), sanding slightly with very fine paper between coats and after the second coat.
My question is whether I should proceed directly to the first coat of the hull paint (going to start with the interior and then do the exterior), or whether I should prime (using an off-white or very light gray primer color) both inside and out before going to color.
Any advice or guidance will be appreciated.
TIA
Ed Kant
Naples, FL
PS: Here are a couple of pix of where I am currently.
TIA
Ed Kant
Naples, FL
