Thanks for everyone's input. It well appreciated. I am moving forward with this build.
Mistakes I made thus far are:
- Faring. I know I screwed up on this.
- When I formed the bends I and glued later, I realized the clamps forced the horrible bend I have so will find better way of holding planks while they form. I used hot water to soften planks and then dry fitted for drying. I have a plank bender coming in for future use. Though I still might use steam in some use cases.
- I didn't properly angle the bottom of planks for over lap and even had to rebend one plank because I had it backwards. Noticed this mistake after it dried and I went to glue on.
- When I glued planks in on the starboard side I screwed up and glued one overlapping too much with the middle board.
Had a lot of trouble with the ribs and kept break one rib and fixing it.
Lot's of lessons learned. Well worth it. I've ordered another of these kits from ModelExpo only 39.00USD and will build again. Applying new knowledge to it for a better outcome.
I don't get frustrated I learn. My ultimate goal is the USS Cutty Sark. Slow and methodical. After I do the Grand Banks Dory successfully I will attempt the Norweigan Pram and then the Muscongus Bay Lobster Smack. Not sure where I will go from there but this is a fun ride.
I spent many years doing plastic models and just loved the tall sailing ships. Always wanted to do wooden models. Just didn't have the time to invest. Now I am retired and have the time.
Cheers folks.
