**VIEW THREAD HERE** |
You can use a medical bulb to blow away dust.
Do be careful with those, because they will blow parts off. The airbrush is good because you can control the volume of air. Even better is a small handheld vacuum nozzle to suck up the dust you raise with the makeup brush. As opposed to blowing dust around to resettle on the other models…Or those cans of pressurised gas used for cleaning computers perhaps.
Quite so. That’s why I wouldn’t use it for directly removing dust (not to mention trying to navigate something so bulky amongst all that rigging). Rather, it’s for sucking up what’s already airborne so you never get it close enough to do damage. A vacuum generates less force on a given point than a jet of pressurized air.And do be careful with those as well, because they can suck your parts clean off.
I would think mass of air flow only comes into play if you let the nozzle get dangerously close to the model. The point is to use it to suck dust out of the air, rather than straight off the model. Same idea as a spray boothNow that is an interesting assertion. I agree with you if we are only considering static pressure but what if we include the mass of the airflow?
Blowing,Brushing with a soft brush or Spraying the solid parts with a diluted transparent varnishA friend has inherited some wonderful models that were NOT kept under raps for more than several months. Any suggestion how to clean off the rather adherent dust and dirt?
True. The thing to keep in mind is that it is the velocity of the air that can cause damage, not the volume of air. In the case of a vacuum cleaner, the velocity is highest at the nozzle and drops off quickly with distance from the nozzle. Fair winds!I would think mass of air flow only comes into play if you let the nozzle get dangerously close to the model. The point is to use it to suck dust out of the air, rather than straight off the model. Same idea as a spray booth
