IJN Fuso 1944 by wieslaw_ - Halinski - 1/200 - CARD - with 3D print
I decided to copy the whole build thread from another forum, so sorry for dropping so many posts one after another. From now on, I’ll be updating this thread more regularly. Moving on...
I would like to present you with a slightly shortened version of the progress report from the construction of my paper (and 3D printed) model of the IJN Fuso battleship in 1/200 scale.
I will make a short introduction to bring you up to date. I started this model around January 2010, which was a long, long time ago. Unfortunately, every time I tried to return to this model, I always had some personal issues in my life.
The hull was based on a cardboard model from Military Model No. 1-2/2007.
Below are some photos of how I started and where I was at the beginning of 2022.
Hull frames:
After a lot of work, I finally got a base shape:
Wooden deck:
Hull ready for painting:
Hull painted:
Below are my first Sonic Mini 8K prints:
On the Olfa Cutting-mat with a centimeter scale:
I started making the funnel superstructure and the details on the deck:
Some photos of the funnel and 3D printed parts before being placed on the deck:
I'm still in the process of making the funnel superstructure. I did come across a small problem with a template that was too short, but I've managed to solve it. To make the "vents" I used Mr Halinski's phenomenal set of photo-etched parts dedicated to this model.
Funnel steam and smoke pipes. I made them in 3D based on Fuso's monograph from the Anatomy of the Ship by Mr Janusz Skulski. The pipes themselves could've been made from some wire but I didn't have any at that time.
Next, I managed to make the platforms for the searchlights, and I tested the railing templates I had printed. I think that they passed the test. To make it more detailed, I added overlay covers with rivets on them. Let's say it's just a small experiment of mine that should give results when it comes to the wash at the end. I still have to do two more small platforms on the sides of the funnel and two radar antennas.
All the elements of the front platform:
Assembled platform:
Railing template:
All the parts in place without glueing:
Painted platforms:
The state of the model as of early 2025: I’ve almost finished all the tiny details, and to be honest, I’ve had enough of them, so I’m looking forward to taking a break from those. The goal for the coming months will be the guns, followed by the bow superstructure — the feature that makes this battleship so distinctive (some people love it, while others turn it into memes).
Hey,
Since the beginning of the year, I’ve been working on the main artillery for IJN Fuso. Below is a brief summary of the past three months.
In the first photo, you can see the barrels from Haliński's accessory set (I’ll talk more about the barrels later), along with additional parts that I designed based on elements from the model but printed on a 3D printer.
The next two photos show all the elements of the turret frames, plus the axes—already removed from the supports—on which I’ll mount the barrels.
I sanded down the clamps on the barrels that held the training mechanism mounts because, they would have interfered with fitting the skirts, which I wanted to print in resin.
Here’s an issues with the barrels: one of them was 0.8mm shorter, so I had to extend it to match the length. The barrels also had slight differences in diameter, which made fitting the skirts quite a challenge.
Ballast in the turrets—here, I admit I borrowed the idea from polish forum.
The next few photos show the underlayer and the assembly of the main components.
I also started assembling the rangefinder covers. To help with this, I designed and printed a small template to achieve the correct profile of the covers (probably thermal covers?).
Since the entire model was going to be painted, I wanted to add more texture, so I also printed the sheet metal joints with rivets.
AA gun platforms.
In these pictures, you can see a screenshot from a fabric simulation program (Marvelous Designer). If anyone’s interested, I can write more about it later. The advantage of this approach is the realistic-looking skirts; the downside is that the barrels can’t be elevated. You can work around this somewhat by printing skirts in different raised positions, but they’ll still be fixed in place. However, I find this solution interesting and worth considering.
Once I had added so many details to the turrets that handling them without breaking something became impossible (I think I broke the ladder railings about ten times), I finally decided to print a stand for the guns, which allowed me to continue working on them.
The guns assembled and painted.
After weathering.
This is excellent modeling skills and as a result an awesome model. It seems most parts are 3D printed, I am curious what parts are made from cardboard?
Most of the small parts I designed and 3D printed based on the plans included in Skulski's monograph Anatomy of the Ship. Large structures like the superstructures, guns, and of course the hull itself—but also stairways or 25mm gun shields, 150mm guns, etc.—are made of paper.
