Billings Boats Cutty Sark
Oh wow. Yes, I think I'd be a bit reluctant to give that up too.
And yes, you're absolutely right, I see them now on the Campbell plans. Portable anchor davit, also used for accommodation ladder. Well, well, you learn something new every day. As my 1:96 build is parked pending inspiration, I think I'll add these davits when I go back to it. There's not an awful lot going on, on the CS deck, so any extras are welcome as far as I'm concerned. As it happens, I was out shopping with my other half this week and ended up in a fabric shop, from where I bought some very thin silk fabric and will be having another go at making half-furled sails - the sticking point - some time in the future.
I find it helpful if I bog down on one end to go down the other end for a while. There isn't much in the middle.
It is said fortune favours the brave but apart from a few times when this thing has tested me it's coming together and the summer has been fairly productive. Billing's with their scarcity of instructions invites you to innovate and that putting it mildly.View attachment 516095
Both stem and stern have turned out to be correctly shaped to my eye at least. Bulwarks have been modified to more closely resemble the real deal. Onto deck fittings. I got a set of etchings and rigging blocks from Hismodels. Even from Australia it was hassle free and great service. I did however swallow hard when I saw how small a 2.5mm deadeye is. I have no idea how how threading those is going to go. Especially seeing as they won't be that accessible when attached to the railings. My wife has a large magnifying glas on a flexible stand with light. I may have to requisition it under emergency powers.
Work is coming to a halt in a couple of weeks. My attempt at retiring has failed miserably and I'm heading north to Canada for about 4 months work and then I shall try a further attempt at retirement. Thats the plan anyhow.View attachment 516090View attachment 516092View attachment 516094
Quite a lot of progress since I looked in last time! Splendid work. I left the forward davits off mainly because they are not on the ship as she is now and I was not able to find any references as to when they were fitted/removed. They were certainly not present when she was sailing as the Ferreria and were not reinstalled by Captain Dowman. I see you have run the anchor chains to the chain pipes, this is a detail I have puzzled about because I would have thought that the chains would have torn up the deck planking and damaged the forward hatch coaming running as they do, but I have not seen any references that chain plates were attached to the decks?? Anyway i will do the same when I fit the chains
My CS is rather becalmed at the momentum (too much other stuff to do!). I have been tinkering with the masts and yards but no real progress.
Love the office!! That's a very skilful job!
Dom
Dom
Another detail I've noticed but not on Campbell is the cabin access at the rear of poop cabin. I came across an old photo that shows it so obviously a fairly early modification. FB_IMG_1745712992890.jpg
if I bog down
I bogged down big-time on the masts and sails, as I am making these from scratch using resin printing. I found that there is a confluence of interdependent things at that point; the rigging depends on whether there will be sails, the yards depend on what rigging there will be, likewise the pinrails, and so on and on.
I think everyone finds this to be a strange arrangement. I can see how the crew would probably keep the chain suspended while winching, but what about when the ship is out at sea? Unless they detached the chain from the anchor once catted and just had a lead rope or something running down into the chain locker.
I'd assumed this was a fairly modern modification geared to it being a museum ship but clearly that it not the case. See the huge chimney stack too - tiny on Campbell. You have me re-appraising what I've done and wondering whether I might go back a few steps!
I could not find out when the rear cabin access was added but I have seen some images that suggest it was around the time she was on the wool runs or just after. he forward access was also extended forward at some point but I think that was a later change. The model is correct according to Campbell's plans so that's fine. I just read Kevin's comment regarding the forward davits, I also didn't realise they were portable and were unshipped when not in use. I looked through my photographs and it was not obvious how they were fitted because there doesn't appear to be any sockets in the Forecastle deck for them (at least not that I could see in my pictures and I didn't look for them specifically when I was on the ship). I am leaving them off mainly because I don't want to be drilling holes in the deck now - and yes, I am sure I will catch them and knock them off! The picture you have also shows that the decorative scroll work was different to what is on the ship now (similarly on the bow plates).
Dom
Bearing in mind the ship that you see now is largely a replica, following the big fire in 2007, I'd hazard a guess that they didn't bother creating the fore davit sockets. I had a trawl through my photos earlier and couldn't see any sign of them. The restoration around the foredeck is a bit messy anyway, the rails are only partially attached and hang loose at either end IIRC.
I like the revamped forward access, which is how it's presented in the Revell kit and in real life today. It was fun to make and, as I need to repair some of the porthole glasses, I'm tempted now to add the stern entrance as well. Though probably not that blast furnace sized chimney.
The rear cabin access would have to have been a damned good idea on someones part. It would have been a treacherous walk on the deck to gain the forward access especially in the Southern Oceans. I found a few more old pics on a Facebook group called Southern Tall Ships. So just to add further confusion note in particular the extra davits by the forward cabin and reduced ratlines on the mast stays.1000005553.jpg1000005554.jpg1000005555.jpg1000005556.jpg1000005557.jpg
That's a pretty different layout - two booby hatches, both appearing to be as tall as the cabins, lifeboats on the forward cabin etc. It's a far more industrial looking ship than now, which I guess was what it was all about. The 4th photo really emphasises how tall were the masts, doesn't it.
Well, this is a lesson for a guy before he gets too far down the rabbit hole of rebuilding a rescued kit discovered from someone who gave up before I found it! Looks like I have much more to study and decide before I get carried away thinking I have it all mapped out in a logical order. Not! Thank you for posting the pictures and the pieces of information a person should have a read of. Nice work and a little OCD goes a long way to enjoying the result.
Shaun
Shaun, as I’m sure you’ve gathered there are probably dozens of Cutty Sarks you could build and any one of them will be true to some period in her life. The good thing with this ship is that there’s a lot of info out there, including on this forum.
Have some excel sheets I did for blocks and lengths/color of rope/wire for standing rigging. Includes lifts.
Also suggest you get rigging diagram from Cutty Sark Museum. Billings plan leaves much out. Also have 1972 instruction book, although that is not much help. Let me know.
Jim
I hear what you are saying Kevin. I have been thinking about this one carefully and have likened it to when I built my woodworking bench. I poured over ideas and types, classic, traditional, Roubo, modified Roubo, Tail vice, no tail vice, hold downs, hold ups, type of wood to make it with, pros and cons and the list went on. So last night I came down to these thoughts on my Cutty Sark build with my workbench experience in mind.
Who am I building it for? Customer, no, friend no, for sale, no.
I am building it for me and the enjoyment of the hobby, to display in my space to look at and ponder life in those times of great sailing ships. To learn some history thru research of a ship with a storied past, in my humble opinion at least. In reality I think like you say there are really many updates and versions of her thru the years, no one gets that for in life without some work ! She was in the tea trade, the wool trade, renamed, left to rot tied to some forgotten jetty, rebuilt, burnt twice and rebuilt / refurbished again, I mean that is a whole history to itself isn't it. So Kevin I agree whole heartedly with your thoughts, build on! Well some reading first though right ;) .
Progress on this beast has been slow and I can find any number of excuses. I think some times when you hit a road block on the build you just have to walk away for a bit. My problem were the rails and the deadeyes. At 1:75 some of those deadeyes are tiny (and slippery). Attaching them to the rail does present a challenge. Tried wire for the 2.5 deadeyes but wasn't happy. settled on twisting thread and setting with CA and then painting. Good enough. The real CS has any amount of rope coils on the rails. I will use them to advantage. Bit like a fig leaf in a painting of Adam and Eve hiding the rude bits.
Got some extras from kevin at KTL. Ships boats, rails and fife rails. They are well worth the outlay. Thankyou Kevin.
That big empty deck is starting to look not so empty. Hismodels was a good source of CS extras. Got standing rigging blocks and photo etched trim.
Next stage coming fast is going to be the masts. I am thinking about just putting in the lower masts first and get the lower shrouds on then adding the upper masts later. That has the potential to be a brilliant idea or a glorious mistake. Thoughts would be welcome. A shopping order with somewhere like Cornwall Models is coming up. I just need to get some more brass fittings in for the masts and yards. I am pretty certain there is nothing here down under. I have been using some photo etched eyes that I got from Hismodels. They have proved an excellent replacements forIMG_20251218_122400.jpgIMG_20260206_155810.jpgIMG_20260206_155910.jpgIMG_20260206_155924.jpgIMG_20260206_155958.jpgIMG_20260206_160012.jpgIMG_20260206_160021.jpgIMG_20260206_160106.jpgIMG_20260206_160210.jpgIMG_20260206_160219.jpgIMG_20260214_152204 (1).jpg the standard eyes found in kits. Just looking at the number of eyes needed for the jackstays makes me think they may be perfect for that job. So thats another order. Might blow care to the wind and get the set of running blocks at the same time.
While that is in progress it is going to be study time between Longridge and Campbell.
Next stage coming fast is going to be the masts. I am thinking about just putting in the lower masts first and get the lower shrouds on then adding the upper masts later. That has the potential to be a brilliant idea or a glorious mistake. Thoughts would be welcome. A shopping order with somewhere like Cornwall Models is coming up. I just need to get some more brass fittings in for the masts and yards. I am pretty certain there is nothing here down under. I have been using some photo etched eyes that I got from Hismodels. They have proved an excellent replacements forView attachment 578213View attachment 578214View attachment 578215View attachment 578216View attachment 578217View attachment 578218View attachment 578219View attachment 578220View attachment 578221View attachment 578222View attachment 578223 the standard eyes found in kits. Just looking at the number of eyes needed for the jackstays makes me think they may be perfect for that job. So thats another order. Might blow care to the wind and get the set of running blocks at the same time.
Looking good! I used some 0.2mm twisted wire for the jackstay eyes so that I could reduce the size of the rod diameter to 0.5mm which is more to scale size but it was a real pain to make all the eyes and fit them to the yards! I'm working on the masts at the moment which has been slow going and I hope to have them finished in the next day or so and will post an update. I am thinking of fixing the lower and top mast sections together first, rig the lower shrouds and stays and leave the royals off until later. I did buy the full set of rigging blocks and sails from HiSModel which is enough to rig according to Campbell's plans but, sooooooooo much rigging!
