Now they are showingHello my friend,
can you see the pictures now? That would make me very happy. You are also welcome to comment on them.
Best regards
Günter
**VIEW THREAD HERE** |
Best regards
Günter
Good evening Gunther. These little boats are quite the challenge and you are owning it. Cheers GrantAhoy, gentlemen,
I've been able to build a bit more on the Athena. As I'm still not sure how to build the lower deck, I've turned my attention to the dinghy (lifeboat). That's a real piece of work ;-) Everything is so small. But I don't want to complain and am doing my best.
I've started with the hull planking and one half is finished. I still have to plank the other half. Then I've finished the main mast, bowsprit and sail mast. I sanded everything down and rounded it off. I'm going to sew a fabric sail on the sail mast. I also tried to make a nail in a slip. It was really not easy and I think I broke 10 or 20 toothpicks. But look at the pictures. I hope you like them. Unfortunately I'm very busy at work at the moment and so the construction of the Athena will be delayed a bit. But I'll persevere and finish it. I promise,
Best regards
Günther
Here I have bent the planks!
You can see the differences in the document nails.
On the left-hand side is my finished nail!
On the right side is the purchased nail.
Good afternoon. I agree with Paul. Stunning work at this scale- kudos. Cheers GrantDear Sirs,
I have another small update from my Lifeboat.
It's really fun to design it, but it's very difficult to build a really nice model in this scale. I'm trying very hard and hope you like it as much as I do.
What have I done to it so far?
I have sanded and fitted the frames. The formers have a thickness of 0.5 mm and a width of 1 mm. It's quite a challenge to install something like this without it tearing. Then I sanded down the planks above and fitted new ones. I had to put them together from several parts. Here, too, the width was
2 mm and 0.5 mm thick. Then I laid out the floor. For this I had to use
glue 2 x 3mm wide linden strips together, shape them and insert them. I had to glue this onto 1 mm x 0.5 mm wide lime strips as a base for the other 6 lime strips. These measure 2 mm x 5 cm. I also had to sand these down.
Then I made the gratings from walnut wood with 0.75 mm holes and then framed them with 1.5 mm lime strips and sanded them.
Then the grating at the rear was also made from walnut. Also with 0.75 mm holes and 1.5 mm lime strips in the framing.
Next steps:
Installation of the seat boards, insertion of the stern tiller.
Outstanding work;
Sanding, varnishing, painting.Then I will take care of the accessories.I'll make the sail myself, rudder, water keg, covering nails, metal gables, mast bowsprit, thimbles, ropes
I'll make the sail myself, the water keg, the covering nails, metal gables, mast, bowsprit, tiller, thimbles, ropes and fastening rings.
So there's still a lot to do and I'll be very happy when I can tell you the results.
I can also tell you how much has been broken.
35 toothpicks
10 limewood strips 2 mm x 0.5
20 limewood strips 1 mm x 0.5
2 gratings a 0.75 mm x 4 cm x 4 cm
lots of superglue, wood glue
and a lot of sweat.....)
Best redards
Günther
