I give up!!! I am half-way through rigging my HMS Ontario by Maris Stella. I up-graded the kit to include "beautiful blocks" which, indeed, are beautiful and very realistic. However, I find that these blocks (probably because of their smoothness and material (ebony?) are slippery little buggers that literally leap off the workbench, similar to those lawn weeds that pop seeds all over if merely touched. Their manufacture may involve the use of a lubricant as well? I can handle these new blocks if they are 5mm or larger, but find it almost impossible to prep for use if they are 3mm or smaller. In my younger days I had been able to handle even 2mm blocks (made out of cast metal) but eyes and arthritis have eroded my abilities in this area. I have an ample supply of older blocks that I can still handle at the smaller sizes.
One another matter (still involving rigging of blocks), I typically use a tool that has a couple of alligator clips, attached to metal adjustable rods that themselves are attached to a heavy metal base (I am sure that you get the idea, but I simply don't know this tool's proper name). This tool extends its reach to, perhaps, 8-10 inches. However, when stropping a block, say at the top gallant level, it is useless. I am forced to do it with my fingers alone resulting in a less than perfect job. Are there any ideas out there as to how one can strop a block or whip a stay at the higher elevations?
