- Jun 13, 2022
If it is not to late for my tuppence worth, I also a use a scalpel and a sheet (1/4 inch) aluminium, works grate.Thanks all for the responses, much appreciated. I will look into the options suggested to see what works best for me.
Never too late JJ ... always open to other suggestions. ThanksIf it is not to late for my tuppence worth, I also a use a scalpel and a sheet (1/4 inch) aluminium, works grate.
JJ..
Thanks RogerI find these very good the point gets in the smallest spaces and the curved blades allow you to trim easily
My way of dealing with those 'inappropriate' brass ladders was to chuck 'em into the 'might-come-in-useful' box, & make 'proper' wooden 'uns!Ahoy shipmates. When cutting brass fittings are there any suggested tools/approaches? I have tried scalpels or just twisting off and then using a small file to tidy up. Thank you in advance for any guidance View attachment 523001
Thanks Stuart think I will try the brass ones first as probably more to scale for EnduranceMy way of dealing with those 'inappropriate' brass ladders was to chuck 'em into the 'might-come-in-useful' box, & make 'proper' wooden 'uns!for my OcCre Beagle. Thinks:- maybe they are to represent metal stairs?
I use fine nippers to separate etched parts.
Stuart
Stuart
Thanks for the responseThese are big but effective. I can also use these for anything that needs a heavy duty scissor action.
Thank you. Certainly quicker than a full buildLooks like you did a fine job there, Keith. She should be very happy!
