Thank you ir3 for the toys/tools.
These things are very well built/soild I can’t wait to put them to good use View attachment 524166
Did you guys get the repeating arm also? I did but haven't used mine yet.
I did not get one, maybe a future toy purchaseDid you guys get the repeating arm also? I did but haven't used mine yet.
I just clamped it down with two clamps, seems to be working wellI think these things are 'GREAT'! I'll be mounting mine to wood or MDF bases to keep them from scooting all over the place and to add more weight to the chopper so it doesn't come off of the table when the arm is raised up. I'm quite happy with these tools!
I don't like clamping because it anchors the tools down. I like to use them, move them out of the way then drag 'em back for use again as needed.I just clamped it down with two clamps, seems to be working well
LOL The clamps are temporary. Just take them off and you can move it.I don't like clamping because it anchors the tools down. I like to use them, move them out of the way then drag 'em back for use again as needed.![]()
That's my plan 'EXACTLY'! I'll be using thicker wood though, extra weight, but 'you've' got the idea!No clamp... but I did add a small base to improve stability. Working great! Hold in place with double-sided tape.
Hi Y.T.I wish the grinder would have a motor attached to it.
I bought the Proxon disk sander which works great and is fairly compact. It is also cheaper than the ultimation.I wish the grinder would have a motor attached to it.
Appears OK, BUT... how does one cope when both hands are required to hold the workpiece?No clamp... but I did add a small base to improve stability, so it does not rock to one side or the other. Working great! Hold in place with double-sided tape. I do use the repeater all the time... it's very precise and reproducible.
