This is the one I used. Good quality. Amati Cornwall linkThese are 2mm o/d 0.5mm shaft they are copper and available from Cornwall model boats ltd they are very cheap but i suspect the postage would be the killer but you may be able to source them locally
I agree this is an easier way to go IF they are the right size. The problem is we have a variety of scales in our models, there are ring bolts as well as eye bolts and there were various sizes of each on the ship. The cost of using a few bits of wire to make hundreds of eye bolts or ring bolts in the home shop in a variety of sizes costs next to nothing in money or time.All good ideas, but for me, I search the low cost, an Amati A4703 gives you 100 pins for a peanut.
You're right. For amati ship of 1/64 it is good. Must check else where for other size, not easy to find...I agree this is an easier way to go IF they are the right size. The problem is we have a variety of scales in our models, there are ring bolts as well as eye bolts and there were various sizes of each on the ship. The cost of using a few bits of wire to make hundreds of eye bolts or ring bolts in the home shop in a variety of sizes costs next to nothing in money or time.
Thanks Allan, I was mislead by incorrect translation. I invert the terms (eyepin and ringbolt vs ring). Thanks for showing me the pictures which is very clear.The eye bolt holding a ring (ring bolt) has an ID that is even smaller than most eyebolts so probably easier to make than find pre-made. The below is for 1:64 scale for a typical ring bolt for a 5" circumference breeching line as an example which would be for a 12 pounder or 18 pounder. Sizes are approximate, but should be pretty close. 0.4mm material is the same as 26 gage copper wire. Under $10 US for 100 feet. There is some offered with a black coating so there is no need to blacken it with liver of sulfur or paint.
