Removing pencil marks
When working on a ship, every now and then a pencil mark is necessary on a visible surface. I know that sanding is an effective way to remove them but depending on the wood, the lead marks, however lightly applied can “sink” into the grain making sanding less effective. This makes sense given that pencil lead is often a viable shortcut to represent caulking. Is there a solvent or a technique that works in removing unwanted lead marks when sanding can’t, or shouldn’t, get deep enough to do the job?
1. Try a "pink" rubber eraser. cheap and available everywhere.
As a graphic artist I used something called a 'putty rubber'.
Removes pencil lead like a magnate.
It helps to use a 4B lead in a micro propelling pencil.
HB and harder leads will mark the wood.
Like many things, a tender touch is the way to stroke the line.
