Varnish Recommendations
Coral Gables, Florida
Hello everyone,
I’m about to begin working on two Artesanía Latina kits — La Pinta and La Santa María — and I’d love to get your input on varnish options.
Could anyone recommend good varnishes that:
  • Work well with the wood typically used in these kits,
  • Are available in the U.S. (or easy to order online),
  • And offer a finish that suits historical ship models (I’m leaning toward satin or matte, but open to suggestions)?
Any tips on brands, application techniques, or what to avoid would be greatly appreciated. Thanks in advance for your help!
Best,
Carlos
I have used Rustin's stain and varnish for ship building, furniture and other woodworking projects for years and it is a consistently good product. Their fast drying Satin varnish is good (15 minutes to touch dry), but is milky on application so go thin and avoid thick edges as they may dry white; that is true for all fast drying varnishes. Sorry, not sure if it is available in the US in stores or on US Amazon.
If spraying I use a rattle can, brand name is 'Polar'.
You can also get good results with acrylic (water based) varnishes, but these take an extra couple of coats as they are very thin.
As my Dad used to say - two coats are better than one.
Rub down between coats using very fine wire wool, but make sure you dust down well.
Avoid - yacht varnish. It has it's uses, but can take up to 8 hours to dry.
I hope this helps.
I hope this helps.
Thanks for the great tips! I’ll definitely keep an eye out for Rustin’s, available online with Amazon. Good to know about the milky look with thick coats — that’s a helpful warning. I appreciate the Polar spray tip and the reminder that acrylics need more coats. And yes — your dad’s “two coats are better than one” is spot on!
Testor’s Dullcote. Mass market brands like Rustoleum also sell Matt varnishes in rattle cans. Probably the same stuff, Just in a bigger can.
I doubt if these rattle can finishes are actually varnishes. I believe that they are actually nitrocellulose lacquers. They can be sprayed to provide a thin coat and they dry rapidly.
Roger
I’m one for shellac as you can
Apply multiple coats a day
It dries quickly.
It’s durable.
It sands easily.
It’s readily available in clear, amber and orange colors.
You can also buy it in flakes.
And the biggest thing for me.
It has longevity.
The milky color comes from moisture in the air. Do not apply varnish in highly humid air. If you do get the milky color let it dry good and then lightly sand the milky part and redo with more varnish on a less humid day. Best to varnish in a small room that is comfortably heated with low humidity. Two light coats is better than one heavy coat. Several coats will give some depth to the finished product.
While clean-up is a bit more onerous, I would recommend only using oil-based clear coatings. I avoid water-based coatings entirely for a variety of reasons, including, but not limited to: 1. their tendency to raise the wood's grain, 2. their tendency to be thicker, thereby obliterating fine detail, and 3. their unverified archival qualities.
Which finish to use is a matter of what effect you want to create. Gloss finishes are to be avoided in modeling because they are not realistic and detract from the compelling impression of reality that is the objective of modeling. "Eggshell" and matte finishes are preferred, but with clear finishes, prepared (i.e. "canned") matte finishes are problematic. Most are simply clear finishes that have been "dulled" by the addition of very fine "dust" material that produces a microscopically rough surface on the dried or cured coating. The primary problem with "satin varnishes" and the like is that it is extremely important to keep the flattening additive in an even suspension in the coating when applying it. This requires frequent thorough stirring (always stirred, never shaken!) and that adds the risk of introducing air bubbles into the coating which will ruin the finish. If the flattening medium is allowed to settle in the coating and the varnish is applied from the top of the container, a gloss finish will be obtained because the "satin" medium is still in the bottom of the can! (Don't ask me how I know this. :))
If one wishes to use a varnish, the best approach is to use a quality gloss marine spar varnish (also properly stirred, never shaken) with a good UV inhibiter. This UV inhibiter prevents degradation of the varnish due to UV radiation. (Of course, however, for this same reason, no ship model should ever by displayed where it may be exposed to direct sunlight.) Varnish will dry to a gloss finish and when it is fully cured (several days,) it can be hand rubbed with pumice and rottenstone, very fine steel wool, or a Scotch-brite pad, to "knock the shine off" to the level of reflectiveness or lack thereof one desires. Hand rubbing also improves the finish by removing small dust specks, etc., which may have stuck to the tacky finish before it dried fully. It produces a perfectly fair and evenly reflective finish that cannot be equaled by anything that comes in a can. Shellac is treated in the same way. Shellac (as it comes from the can, being thinned with alcohol) will readily soak into bare wood and show no gloss, but when subsequent coats are applied, they will build to a gloss finish. Shellac can be hand-rubbed in the same way as varnish to flatten the finish.
Shellac can also be used to create a French polish finish. This involves hand-rubbing a mixture of thinned shellac and linseed oil into the wood using a cloth polishing pad. French polishing produces one of the most beautiful gloss furniture finishes possible, having great depth and light reflectiveness, but it requires a bit of skill, experience, and a lot of "elbow grease. I don't consider it suitable for ship models because of their shape and surface details. I leave French polishing for flat tabletops.
A very good non-gloss clear coating material for ship models is what is popularly called "wipe-on poly." This is simply thinned clear polyurethane coating. It's applied by simply brushing some onto the surface and spreading it by wiping with a clean cloth or applying to a cloth and wiping it on with the cloth. It soaks into the surface and with repeated applications will build on the surface. (Follow the instructions on the can, as everybody should and few do.) Minwax and Watco make it in the U.S. It comes in clear and in a range of wood stain colors. It also comes in oil (solvent thinned) based and water-based versions. I prefer the oil-based version over water based as previously mentioned with respect to varnish. You can buy pre-thinned "Wipe-On Poly" or you can buy regular polyurethane varnish and thin it yourself with some mineral spirits. The price of the two is roughly identical, so if you buy the pre-thinned "Wipe-On," you're paying a lot of money for inexpensive thinner. If you thin your own, you're getting a full can of polyurethane varnish, not half or two thirds a can of real varnish and the rest cheap thinner. It doesn't matter one way or the other, but if you're as cheap as I am, you'll go for the un-thinned and thin it yourself. I would say that for a "bright" (clear) wood finish on a ship model, wiping on thinned polyurethane clear coating is the easiest, most foolproof method and really looks as good as any other option.
While some favor finishing oils to finish models, I do not. For one thing, all finishing oils are pretty much equal. Real "tung oil" from tung nuts is generally somewhat thicker than linseed oil (which is the same thing as flax seed oil in the health food store,) but not much different otherwise. The only thing "teak" about "teak oil" is the name on the can. It is not made from teak trees. They just call it that on the can and charge more for it. Oil takes a long time to polymerize ("dry") and is messy stuff to work with, particularly on a detailed surface like a ship model. ("Boiled" linseed oil isn't actually boiled at all. It has Japan drier added to acceleration polymerization so it dries somewhat faster than "raw" linseed oil, which can take weeks to "dry.") Other than that, wiping on thinned finishing oils will yield a finish comparable to "wipe-on" thinned polyurethane coating, but likely take much longer to "dry."
Two points you may also wish to consider are:
One, any glue residue on the surface of the wood (E.g., thinned CA or PVA adhesives soaked into the wood) will cause an uneven coloration of the glue-coated wood when a clear finish is applied. A stained finish will similarly be uneven in such instances. Unless the wood surface to be finished showing the wood's coloration is completely free of any glue, any attempt to finish it bright will likely result in disappointing, if not unacceptable, results. One way to test the wood surface for this impediment before applying a finish is to wet the bare wood with a fine spray of water. The wet surface of the bare wood will show any unevenness in coloration in the same manner than it will show when a wet coating is applied. While this may raise the wood grain and require a fine sanding before final finishing, it's worth the effort and cheap insurance against a finishing disaster. If the offending glue cannot be sanded out of the wood without ruining the fairness of the surface, there's nothing for it but to abandon hope for a bright finish and paint the wood instead.
Two, although we have no historical evidence of what the two Fifteenth Century vessels you are modeling actually looked like, it is safe to assume they were never finished "bright" with varnish. They were undoubtedly "tarred" with what today is called "boat soup," a mixture of pine tar, linseed oil, and turpentine. While the initial coats of "tar" would have been thin enough for some wood figuring to show through, in a very short time, additional coats and the effect of weathering would have yielded a very dark brown color that, from a scale viewing distance, if not up close, would have appeared to be flat black. (And to this I can attest from my first-hand experience with one of the full-scale "replicas of
Pinta.) Colored paint pigments other than whites and brown shades, were very expensive in the Fifteenth Century and only used, often at the captain's own expense, for decorative accents and then only rarely on working merchant vessels. (Blue pigments, then made from crushed lapis lazuli, were so expensive that they were only used in fine art works.) A "bright" (clear) finish on ship models is a stylistic choice. In most all instances, it bears no resemblance to the actual appearance of a vessel, but some modelers like it. That said, there's nothing wrong with a model that's painted instead of finished bright.
Nitrocellulose or pre cat sealer. They dry fast and once lightly sanded, can be lightly buffed with 0000 steel wool or 400g aluminium oxide abrasive paper and waxed if required.
It gives a very natural finish to timber.
The secret is to thin up to 30% and not to apply too thick.
Great stuff, but, like a lot of "old school" finishing materials, here in California nitrocellulose lacquer is very difficult to source anymore, if not outright illegal in some local jurisdictions. Nitrocellulose itself is classified statewide as a highly hazardous material and compliance with safety regulations has driven the industry to less regulated alternatives. See: https://dir.ca.gov/title8/5187.html
Additionally, local "air quality control districts" limit the sale to unlicensed users of many of the "hot" solvent-based coatings that were once in common use based on their volatile organic compound ("VOC") level standards. In large metropolitan areas, it's even difficult to buy things like raw linseed oil, Japan drier, or real mineral spirits. (All most stores carry now is water-based low VOC "oder-free" "paint thinner" which is pretty useless stuff.) Generally speaking, if it smells like solvent, and it used to really do the job, you can't buy it here anymore! :(
Real nitrocellulose lacquer is still in high demand by top-quality luthiers, and it seems they go to great lengths to source it from areas where it's still available. I suppose they get away with that because there are so few of them, they aren't worth the inspectors going after them. As a kid in the 1950's, there was an auto body shop in the neighborhood that painted cars with nitrocellulose lacquer. I still remember that wonderful aroma of the evaporating solvent coming out of their open shop doors. That's definitely something that is no more around here.
Hi Bob,
Yes, apparently in California everything gives you cancer
I would be more concerned about your governor, his government and their ridiculous ideals than I would about nitrocellulose lacquer!
Hello everyone,
Best,
Carlos
1. DON'T. Use thin solvent based (not water based) lacquer thinned about 60 to 70 percent with lacquer thinner.
I agree with most everything Bob Cleek said, but I would like to offer another perspective.
We are finishing our models more for aesthetics than for protection (assuming your model will not be displayed in a bright sunny window or outdoors.) Any solvent based product (oil, thinned varnish, shellac, etc.) will soak in on the first coat and give you a relatively flat finish. If that's what you desire, you're done. If you want slightly more sheen, put on a second coat. I would go no farther than that for a number of reasons.
The more coats you apply, the more it will become necessary to scuff the surface to allow subsequent coats to adhere. That can be difficult if not impossible on some areas of a delicate ship model. Plus, if you don't get into all the nooks and crannies, they will stick out like a sore thumb.
A rule in the woodworking and furniture industry (in which I work) is that ALL wood surfaces, inside and out, be finished equally, lest uneven moisture incursion cause uneven wood movement. Moisture will migrate in and out of the wood with seasonal changes. If you don't think small pieces of wood can move much with humidity, just G00gle "weather stick". If you've built your model in the typical fashion, you have planked and decked it before any finish is applied. That means there is no finish inside, moisture will permeate faster on the inside than on the outside and cause uneven wood movement which could lead to warping and/or popped glue joints. The fewer coats of finish you put on only one side, the less this is a problem.
If you do use metal wool, use brass or bronze wool. Small particles of the wool will inevitably break off and lodge themselves in the wood grain. Steel wool will eventually rust and show up on your model, the others won't.
Finally, to see any glue spots prior to finishing, I recommend a solvent rather than water. As Bob mentioned, water will raise the grain requiring sanding. Again, this can be difficult on a model without losing detail. Use "real" mineral spirits, alcohol or acetone. I usually use alcohol because it stays long enough to see the spots, but still evaporates quickly. None of the solvents will raise the grain like water does.
Excellent points!
"The more coats you apply..." Coating buildup is to be avoided, to be sure. A common novice mistake is sanding too much. It makes little sense to sand half or more of a coat off to provide a key for the next one. A flat finish doesn't require sanding for the next coat to adhere. Notably, shellac needs no sanding to key the surface. The alcohol solvent softens the surface of the previous coat. The same is true to a lesser extent with "hot" solvent-based paints. Not so with water-based acrylics, however.
There are really two approaches required when painting models. You can sand to fair the "wide open spaces" such as hulls and it is essential that these surfaces are "smooth as a baby's bottom." Defects on a large smooth surface will draw the viewer's eye and destroy the impression of reality. On the other hand, the smaller areas, which is pretty much everywhere else, are impossible to sand evenly. There, it's best to forego trying to sand around portlights, hatches, and so on.
The rule is "more thin coats are better than fewer thick coats. Don't expect to get an even coloration without using a proper base coat.
"...ALL wood surfaces, inside and out, be finished equally, lest uneven moisture incursion cause uneven wood movement. ..."
Yes, all wood moves more than most people think. Shellac is one of the most moisture impermeable coatings known to man. Surprisingly to many, epoxy is not moisture impermeable. Most coatings will slow the absorption of moisture into wood, but none provide total barriers. By coating the entire piece, as noted, the rate of absorption is even, but the wood still moves. Wood swells and shrinks most across the grain in most wood species and much less so over the length of the grain. Thought should be given to the grain orientation of wooden parts, lest this expansion and contraction differential in relation to the grain orientation can cause a model to bust glue joints or even split wood when significant changes in humidity occur.
I have found it worthwhile to seal every wooden part of a model with thin white (clear) shellac (e.g. 2- or 3-pound cut) which soaks into the wood, does not build up and impair detail, and dries invisibly. Not only does this stabilize the rate of wood movement, but it also provides a good base for subsequent coatings. The alcohol in shellac evaporates very quickly, so there's very little time required for it to dry.
"If you do use metal wool, use brass or bronze wool. Small particles of the wool will inevitably break off and lodge themselves in the wood grain. Steel wool will eventually rust and show up on your model, the others won't."
Boy, it sure will! In my full-sized boatbuilding days, I used nothing but bronze woo. (I've never seen brass wool that I can remember.) I used to get it at the chandlery. When all the independent chandleries got bought out by big chains more interested in selling sunglasses and "yachting togs" than real marine hardware, I'd ask for bronze wool and get a blank stare, or else the kid at the counter would think I was pulling his leg. I'm sure bronze wool is available somewhere online now, but I sure haven't seen it on the shelf anywhere in decades. Like a lot of my colleagues, I replaced it with Scotch-Brite abrasive pads and never looked back. (The pads have the advantage of not filling your hands with tiny razor-sharp bits of metal, too!)
"Finally, to see any glue spots prior to finishing, I recommend a solvent rather than water. As Bob mentioned, water will raise the grain requiring sanding. Again, this can be difficult on a model without losing detail. Use "real" mineral spirits, alcohol or acetone. I usually use alcohol because it stays long enough to see the spots, but still evaporates quickly. None of the solvents will raise the grain like water does."
What a great idea! I wipe down workpieces with acetone after using a tack cloth, just to be sure I've got it all. It may be a "belt and suspenders" thing. I dunno. I didn't mention that because it seems a lot of people these days operate on the "if you can smell it, it's dangerous" principle. Alcohol certainly won't hurt you when used responsibly. A tack cloth is also an essential for any fine brushed or sprayed finish in my book.
Like yourself, I learned a lot of what I know about finishing furniture in a furniture factory. I my case, the factory was in a prison where I supervised the convict furniture factory workers.
