In the process of finishing up an AMATI Fifie and am sanding the second planking layer. This is walnut and is taking an inordinate number of hours to get a good smooth hull configuration. I started by using,120 grit sand paper but am now using 80 grit just to take the edges off the planks to round them into rough shape. I'll go back to 120 then finish with 220 grit or finer. Since this is a painted hull, some scratches will be filled with a fairly heavy primer (it's going to be a radio control model). This now is my question for any future models - is walnut a real pain and is there a better choice in outer hull (2nd layer) woods?
