SS James Reckitt
Hi am creating this model a client in 3D for printing, but there are things on the blueprint I do not know what they are, and was wondering if you guys could help me.
On some steam trawler models I has seen this area as a pipe, what for? whats the thing at the end of the pipe? is a bollard? with motor? or just an exhaust?
Thanks in advance.
So far this is how is going
The large pipe height is estimated since is not complete on the blueprints also the large mast size is not there. The anchor hole is not there neither. Should I make a drainage hole along the deck? my plan is to add ribs and hand pass borders later. Sorry if I not use the ship's language.
ghder.
LB
Do you have a profile view you can post as well as the name of the vessel in the original drawing?
Thanks
Alsa have this picture, but am not sure is the SS James R. by counting the letters on the ship name does not match, maybe is just the photo quality.
Thanks with you help and chatgpt found out I need to find a picture of a "steam trawler rudder quadrant" to model it.
Don't put too much stock into anything 'ChatGPT' has to say about something like this. ChatGPT only 'parrots' things posted online by people who say many things, a lot of those things being totally 'false'! The current state of online AI still leaves a lot to be desired... 'nough said!
Agree AI are not good for this so far, found out is not the "quadrant" what I need pictures of, I think is some kind of roller fairlead.
May be like this?
This dotted line in yellow is not on the deck lvl, so is not the chain, so what is that line for? hand rail?
The dotted line is to show that the steering chain pipe runs the full length of the deck house.
In this case it’s showing the port side steering chain plate as a hidden item ( its behind the deck house in Profile)
I believe that it would be above the deck to keep it more rust free from constant seawater exposure.
Though it was greased heavily to stay in good working order.
I have never seen something like that on pictures or trawlers models on the web, anyone has a picture or reference of a steering pipe or chain going along that high?
Most models I have seen handrails there and pipes and chains are on deck level. If you ask me I would prefer it high, because stepping over a chain full of grease over a wet deck! oh boy! Wonder why all this was not under the deck??? a maintenance thing? I would love to see a picture of a steering system with chains from 1900s.
I have to agree that I too, have never seen steering chain pipes located that far above the deck.
They are usually located right at deck level.
It is very possible that this plan is not drawn correctly.
Plans are just that.
It’s a plan.
It’s subject to change.
And unless a draftsman went back after the boat was built and revised his drawings errors would continue.
Not likely to happen for a fishing vessel.
I worked for a yacht builder years ago as a design draftsman.
We always made up a new set of plans during the finishing stages of the build.
These were called As Built plans.
A set was given to the boat.
And a set was placed atop all the other drawings for that particular vessel in the file draw.
That way if anything was needed the top set of plans were the most up to date available.
Is there an outboard profile plan available to view?
I’d be curious to know what is on the house side in way of the steering chain pipes.
If there are no doorways, then I can’t see an issue with them up high as that is the straightest run aft to the steering quadrant.
She has a pretty severe curvature on the deck from the wheelhouse aft.
There are no door I can see on the blueprint.
This on the picture is what I think it is? this is a survivor steam trawler in Yarmouth, called Lydia I found. 1752763830376.png
I think Lydia Eva is younger than SS James R. I have another doubt, notice the door on the back, is rounded, I wonder if the back door, should be rounded or rectangular.
