If I was in Puerto Vallarta I would be in the bay of Banderas fishing for dorado, marlin, snapper and more and never get any model work done.the other in Puerto Vallarta
One tool I can't live without......my library of reference books. I don't read these books for pleasure like a novel, but I do use them as much or more than any tool in the shop.
Hi, not wishing to be pedantic. I think, technically it is a “Vernier”.When I started out on my Syren build I wanted to be as accurate as possible in the general construction. I purchased a caliper to help with the accuracy I wanted but also found, more and more, that I was using the scaled readout by switching between fraction inches, decimal inches and mm. I found it helped since the kit was designed in the imperial system and I am used to primarily working in mm. It is a fast way to convert between scales and again it satisfied my need for personal accuracy.
As I progressed with the build I found myself changing out the kit wood to pear and AYC because I preferred working with it rather than the basswood. That meant obtaining billets of the replacement wood, milling, cutting and sanding to various sizes and checking constantly for repeat accuracy. Further build progression saw me scratch build more and more parts, including brass work, and discarding kit supplied wood and fittings. I did that to learn new skills and most importantly because I was enjoying challenging myself. The smaller the replacements became the more I needed and used the caliper. So much so it is beside me on the workbench constantly.
Initially this “tool” was a “nice to have”. Now it has become a necessary “cannot do without”.
(Edit: changed word micrometer to caliper - thanks Phil @Philski)
My luck seems to be the one tool I can't do without, was the one dropped on the floor and rolled under some benchwork never to be see again, as you didn't know when you last used and dropped it!After following this for a while I've come to the conclusion that "The one tool you can't do without is the one your currently using for the task at hand". Until you stumble across something better. Thanks for the many (low cost and no so low cost) suggestions.
As far as I understand it, the term vernier relates to the printed scale itself on the caliper (6 or 7 in Rick's image). A digital caliper doesn't have the scale thus it wouldn't be as accurate to call it a vernier caliper.As an old millwright (fitter/turner to those Antipodeans and Poms) and not wishing to be pedantic but the correct term is vernier calliper. I still have an old school version which relied on much better eyesight to read than the modern LCD readout. I might add the LCD versions are a much better option to the aged such as most of us in this forum.
https://www.bing.com/ck/a?!&&p=6740...S5jb20vYmlvZ3JhcGh5L1BpZXJyZS1WZXJuaWVy&ntb=1
I also use a headband magnifier. The version I bought from Amazon uses one or two lens in combination to get strong magnification. Its a full headband version that is adjustable so it doesn't have much in the way of fatigue that the earpiece models have. But still, I only put them on when I really need the magnifucation for very small parts. Otherwise its either my bifocals or readers. I had cataract surgery that returned my nearsightedness to 20/20 but these 79 year-old eyes still need all the help they can get.So this surprised me. I have been relying on these for magnification for the last few years.
The LED lamps gave out in only a couple of months, but the glasses work pretty well overall. It came with 5 lenses for varying magnification but I have only ever used the strongest (3.5X). The biggest problem is that they are extremely heavy on the brow and nose and I can only wear them for a limited time. Ever since I have started needing reading glasses I have wondered if higher magnification reading glasses would be fine for modeling. I finally decided to put them to the test and bought a selection of about $50 worth of reading glasses from Amazon.
The result is they are about 200% better. They are so much lighter and give a much wider field of vision than the little magnifier lens does. My go to pairs have been 2.5X for general modeling and 5X for really intricate work. They were between $6-10 each. Since I have worn glasses my entire life I have no problem wearing them for long periods, so they have just been an all around better solution. BTW the 7.5Xs were funny for their poindexter effect but I don't recommend them for modeling.
