Help find Pear Wood. I'm desperate...
Hi,
I purchased pear from Joe Volpe of Modellers Sawmill in New Jersey a couple of years back and was pleased with the wood and customer service. The milled pear wood sheets I purchased were for different thicknesses but on his site he mentions hand-picked sheets. Link below:
I also purchased pear wood billets about one inch thickness of varying lengths from Cook Woods in the USA. I mill them to my own specifications and am using the pear to mostly replace the basswood for my Syren build. The Cook Woods pear is generally great for my purposes but I include the link if that helps you. The site shows you photos of the pieces you may consider buying.
I found that even if the wood was a little grainy looking if I milled to the thickness I wanted for say a certain plank width then cut the edge off the milled sheet to the scaled thickness of my plank there was little to no grain showing. Not sure that makes sense :), so for example if I wanted 1/8” wide planks x 1/16” thick I mill a 1/8” sheet then cut off strips 1/16” thick from the sheet edge. I think though that you are looking for wider pieces? Anyway hope these links help. Stay safe.
For the lightest pear, you might consider bleaching the wood you have to lighten it. I wanted lighter planking on the deck of my Ragusian Carrack, so rather than buying new, used bleach to lighten the walnut in the kit. Experimentation would be required to get the required hue, but it might work. Scroll down from this link to see my process. Obviously, my craftsmanship is not on the level with yours, but it's a possibility for you. Bleaching also lessens grain contrast.
Here
No, absolutely no! Sorry. You will get crap.
This is what I got once when I asked for uniformed colored pear strips ... it led in a bad discussion .. he don't care about customers and their demands.
Dirk
i have 200 board feet of steamed pear and 1,230 pounds of natural pearwood logs ranging from 4 inch to 8 inch diameter but to exactly match what you looking for may be an issue
This is already a cry of the soul, and I hope for your help. In Ukraine, no one can or does not want to help. I've bought a tree a few times before, but each time it didn't fit. I already thought that I was crazy, but below I will show photos that have what I am looking for, and it is real, and not in my head.
What do I need...
There are a couple of shades of pear wood that I need.
Photo 1. On deck: a) pink pear (dark) and b) beige pear (not very light, which is closer to white, but not brown, but yellow-beige).
Photo 2. On the sides above and below the waterline, another shade of pear, but also looks like a beige pear.
Photo 3. The photo below clearly shows the difference between the three shades of pear: dark (pink) pear, light (but not white) and beige (slightly darker than light). And you can see how the color is saturated after the oil.
Photos 4 and 5. Well, the result after applying oil and tinting.
And now I will show you what kind of pear I have and what color it turns out after tests with oil.
I bought this pear and after grinding I saw its banding.
And after cutting it into slats, these color transitions turned out.
And the wood is all like that. I specially developed it with oil after grinding, since for my cutter you need ready-made rails, as they overlap. And this result definitely does not suit me...
I understand that the tree is not plastic and has a structure, but these diagonal color transitions are very noticeable and sheathing is not an option, or even worse - mixed in when the rails are different from each other. The color may vary slightly, but if it is so different and even through diagonal stripes it will be very visible and this is definitely a marriage!
One way out is the most uniform workpiece, in which the fibers run parallel to the wave and there is no significant color difference between the layers.
Kind people, help me find such wood as in the top photos of the references, where the wood is homogeneous and without these diagonal transitions.
1. Take a look at gilmerwoods.com in Oregon.
2. They do not have everything all the time, so you have to check in on a regular basis (daily).
When they have what you want buy it. Don't delay. It is "here today, gone tomorrow".
What do I need...
One way out is the most uniform workpiece, in which the fibers run parallel to the wave and there is no significant color difference between the layers.''
1. Photos i,2,3, and 4, beautiful work.
2. Cut your wood with the grain, not parallel to the edges of the large wood piece.
Don't cut the wood on the bias.
Try here. The owner is Vahur. It will probably take a few email exchanges to communicate what you are looking for (Hobbymill.eu@gmail.com).
Vahur stocks light and 'dark' pear. There is a wait though, it will probably have to be milled to order and he tends to be busy. Getting the boards for home milling is quicker.
Firstly, many thanks to all those who responded and offered their help!!! I really appreciate it!
Now, some answers to everyone.
Not sure if you can access Ali Express or whether the pear wood strips they offer will help..but in case, here you go…View attachment 532938
Thanks for the link. Yes, it is possible to order from Ukraine, but there are three "buts." Firstly - not a small amount of delivery, as well as the product itself. Secondly, there are no live reviews and photos of buyers. And third, the proposed sizes are not suitable. But thanks for the help anyway!
My concern would be that over time it will all oxidize to roughly the same shade, which is why I suggested other woods, like apple or cherry.
I don't argue, there are many opinions on taste and color. But I don't really like cherries and apple trees. I've tried both trees and I'm making from cherries at the moment, but my favourite is the pear. I will still age with bitumen, and the predicted result can surely be achieved with a pear. Plus, cherries prick, I like a pear the most for working with wood, but still thanks for the advice.
Hi,
Thank you very much for the links and your experience, I will study your links, glad for you that you were able to find what you were looking for, I know how desirable it is.
Thank you very much for sharing your bleaching experience. Interesting idea. I understand the principle of this process and am looking for a slightly different solution. I try to find a certain pear colour for the deck, but which is far from white or very light. Rather beige, as in the photo of the reference. But if I need lighter wood I will try your method, thank you very much!
Dirk
Huge thanks for the caution. To be honest, I thought so. I just don't trust sites where there are no live photos, but standard wallpaper. It is unfortunate that you have experienced such a bitter experience. Thank you for saving me from buying, as we say "cat in a bag."
You are right, that's why I turned to the people, since my search led me to a dead end...
Thanks for the link and for your recommendations. Yes, I understand that it was possible to cut wood from a different angle, but I understood this when I covered it with oil. I will try to change the technique.
Hello again,
I have pre-selected a few pieces with the straightest possible grain pattern. The thickness of these pieces is about 2-2.5 cm and the length about 1 m (the longest ones). In terms of colour, light sapwood is the most common. In addition, there is also some darker hardwood and even a little pink in one or two smaller pieces (hardly visible on the attached pictures). As usual, the photos actually lie about the colours and basically it all depends on the lighting (some pictures are taken with flash, some not, hence the difference).
In some of the photos the slats are reversed so you can see both sides.
When assessing the pieces, try not to see the flawed areas and instead focus on the potentially useful ones (professionals do it that way). Anyway, I can cut off the least attractive parts in order to reduce the shipping cost.
I'd estimate everything at about 15kg +/- a couple of kg, and shipping costs at 100 PLN (for about half of what you can see below) to about 165 PLN (for everything shown here), economy mode. Anyway, here is the postage price list (Ukraine belongs to zone 10):
Hello again,
Thank you so much. Naturally, I don't need so much (I don't want to take so much good from you), and tomorrow I will choose, with your permission, the fragment that may suit me. Thanks again!!!
