Where do I buy a wooden Kit from?
I don't understand why people recommend the outdated kits from Amati and Caldercraft, where they are outright garbage for a lot of money and where you have to invest a huge amount of effort and nerves. After all, in the UK there is an excellent manufacturer with modern high-tech models, high quality and copying. Look at the website, look at the models, accessories, watch YouTube videos on assembly. After that, you will never go anywhere near Amati or Caldercraft. And one more detail: the owner of the company, Chris Watton, is the developer of the best models of Amati, Caldercraft and Victory Models. This is his design and development. But now he does many times better, you can't even compare!
The problem with Billings is the materials. The ply for the skeleton is truly apalling, the externals timber the cheapest. 40 years ago the choice was limited, other companies hit the market but Billings made no effort to upgarade to compete. How they've managed to survive must be first time kit buyers? My advice is 'not even with a barge pole'! The Caldercraft is generally considered a class apart. But NOT for a first build! If you MUST build a full rigged ship check out Vanguard, Amati Victory line, Modellers Shipyard. Many Chinese kits are very good quality. Other companies available at Cornwall include Corel, Mantua, Mamoli, OcCre, Dusek etc...all best avoided.
Caldercraft's Victory is also highly accurate. It's always an idea to check this. Their HMS Pickle is another vessel entirely! Ballahoo does not correspond with the NMM plans. The plans can be downloaded from the NMM website for free.
Expect to buy extras, cannons, good quality blocks, planking etc. These can make all the difference.
Probably most 'modellers tools' are useless money wasters, plank benders, nail pushers. There are many ways of bending planks...and pins and nails cause damage and are unnecessary. Mine are in the bin along with all the daft tools I bought!!!
Before you start learn the entire building process, Facebook can help but the advice can be limited by the experience or bad habits of the writer, SOS is a better option.
Fitting and squaring the skeleton, faring the bulkheads, tapering and fitting planks. Research these first.
Great post.....especially on the useless tools! I bought them all and nearly all were about as useful as chocolate frying pan!
Most went to the back of the tool chest never to see the light of day again.
And Utsav so true about pins for planks too. I'm not sure why those myths persist.
Hello Daaveyboy,
Making a choice, one where the kit you choose should help you progress in our hobby, is different for everyone. I see that you've been involved in model building for quite some time and have already created various things. For that reason, I wouldn't necessarily classify you as a beginner. In practice, however, it's often your ambition that determines which kit you move on with.
I myself started around 40 years ago with a simple kit from Billings, the Nordkap. I was completely inexperienced, but I managed to turn it into a nice ship. I wanted more, so I bought the Smit Rotterdam from Billings. Once the hull was finished, it sat in a cabinet for over 30 years, during which I didn’t do any model building at all. When I retired, I bought another kit from Billings, the Elbjorn, to get back into the swing of things. After that, I finished the Smit Rotterdam.
For a long time, I believed that the Smit Rotterdam would be the limit of my model building abilities. That changed when I happened to come across a build log of the Victory. Although I felt this meant setting the bar even higher for myself, I immediately knew: “I want to do this too!”
I began researching the various brands that offer the Victory as a kit and quickly concluded that Caldercraft was the best choice. You pay more, but you also get a lot more. Especially the materials used are of superb quality, certainly when compared to Billings. And I must say, that makes things a lot easier, especially with a 1:74 scale.
That said, the Victory is by no means an easy ship to build, far from it! However, it is a ship for which there is a wealth of documentation, and you’ll need that. There’s also plenty of support available through the forum.
But when choosing a ship of this level of difficulty, I think there’s another important consideration: What do I want to achieve?
If you're looking for a new kit with quick results, then a simpler model is the way to go.
But if your challenge lies in the building process itself, and in the interest of constructing as historically accurate a model as possible, where time is not a factor, then the Victory is a magnificent challenge. It requires great care and a lot of patience to bring such a project to a successful conclusion.
When I started with the Victory three years ago, I had no idea what I was getting myself into. At the moment, I’ve just begun working on the rigging, and I hope to be completely finished in about two years. What I do know is that I’ve thoroughly enjoyed every moment of it so far and still do. And I believe that’s the whole point of it all.
If you’d like to get into the mood a bit, take a look at my build log on SOS, where I’ve written down my experiences ( both mistakes and successes) on a topic-by-topic basis:
https://shipsofscale.com/sosforums/threads/hms-victory-of-caldercraft-by-wil.16072/
Best of luck with your choice!
Hello Daaveyboy,
Hi Iutar, just wondering your opinion on acceptable kit providers, other than Vanguard, I'm afraid they are out of my pay range, excellent quality though. I don't mind a bit of bashing. They haven't been around for long , so what would your goto model provider be, from your building experience? Cheers.
Amati are as cheap as chips, easily good enough for a start particularly when compared with AL, Mamoli, OcCre and....Billings. Caldercraft are pricey, indeed, however there's nothing wrong with the quality. Vanguard has a whole different approach to building so it's difficult to compare with the old traditional builds. And as Frankieg says suitable for bashing. As long as the skeletal structure is accurate you can build with any of them using the parts as templates to bash/scratch with acceptable material. £260 for Amati's Fly is pretty damn cheap.
Also, you can't really bash Chris' kits, you build as supplied, with the traditional kits you can design a ship, say, Aubrey's Sophie which is different to Speedy. There are a few hulls which would do the job with traditionals. Horses etc.
Regards
Bob
Hi all
I am a modeller for over 65 years mainly plastic kits, wooden radio controlled Boats, aeroplanes, and I am on my latest kit Trumpeter 1/200 scale Bismarck with the full Advanced Pontos add on Kit.
I am now planning my next project 6-9 Months down the line HMS Victory Wooden Kit.
Where can I get a good wooden model kit of the HMS Victory? I live in the UK. Billings Boats looks OK
What do I have to look out for scale quality etc?
I do not know the UK, but OCCRE in Spain has a beautiful model. Pricewise in the middle class. Billing are normal, somewhat cheaper- quality. the there the high prices Admiral model, more than 1000 EU
I have researched the Victory choices myself to determine which I will buy although I am 3-5 years out due to my current backlog...however, here are my 2 choices:
1)Caldercraft - I believe the general consensus of most members of being the top of the line. Expensive but most feel the value is there and are happy with their choice. I am 80% on going with this one.
2) Artesania Latina - Anatomy of HMS VICTORY - I am in love with the videos and the look of this model. The more and more I thin about it, I keep moving toward this model. I love that their are complete video instructions and the quality seems to be very high. I am following a few build logs to get more opinions...but I love this model. here is a video.
Double-ditto to what RogerD and Allan just wrote. If you think anything from Billings "looks good," keep looking! Yes, I suppose there will be those who are justifiably proud of their Billings models, but in my experience, Billings is about fifty years behind the times with respect to what today's serious kit builders are entitled to expect for what they pay for a kit. There are lots of HMS Victory kits on the market. If the "chatter" in the online forums is any indication, only a very few are without significant problems. Thousands of Victory kits have been sold over the years, I'm sure. Only a small percentage were ever finished. I would not advise a first-time ship kit builder to tackle Victory under any circumstances and neither does Caldercraft, which speaks volumes for their integrity and quality. The amount of skill, experience, independent research, and after-market supplemental materials required to build any Victory kit cannot be overestimated. Far be it from me to tell anybody else which ship model kit to build. If you don't mind spending the better part of the rest of your life sanding laser-burned char off the edges of wooden parts, by all means, go for it. :D
And, while you are shopping, be aware that many of the kits manufactured in China and some from Russia are simply counterfeits of kits designed and marketed in Europe and North America, albeit with inferior materials and zero customer support when you are up against missing parts, etc.
Considering your stated interests and knowing a bit about live steam model engineering myself, I will hazard to say that I expect a railroad steam engine machined from any of the castings sets on the market today will take less work and less time to complete than a respectable HMS Victory.
Russian kits are some of the highest quality kits I've seen with great quality wood, way better than many european brands so I wouldn't generalize like that. There's great kits and bad kits in any country. Falkonet and Master Korabel are top notch. I have not yet tried Eskadra or the many chinese kits out there but they seem to be top quality as well and have seen so many great reviews so hopefully one day I'll get some of those.
Besides that I agree with others comments that vanguard is excellent quality.
Regards
Bob
I didn't imply that Vanguard is suitable for bashing, they appear to have beautiful kits, although expensive. That was taken out of context, I was more referencing that to cheaper kits, I think all kits may need tweaking, and cheaper ones maybe more so.
Neither was I implying what you thought I was implying!!!
We are describing kits in general terms. My point is that most kits can be bashed but not Vanguard (too many interlocking and prefabricated parts) This is intended as general information for Daveyboy who requested assistance and advice regarding the suitability of kits available. Also to iutar to provide further considerations regarding Amati and Caldercraft.
No worries!Thumbs-Up
